Help with Fisher Bottom Bracket Removal- Mtbr.com
    Jul 2020
    New question here. Help with Fisher Bottom Bracket Removal
    I have a vintage (early 90s) Fisher AL-1 with a press-fit bottom bracket that I'm trying to remove. The bottom bracket has two retaining circular clips that I've removed and two standard looking, sealed bearings on the outside. It looks a lot like this one from a Fisher Mt. Tam.
    Finding bearings shouldn't be too difficult if they are standard bearings. Alas, how does one press the bottom bracket out? I have a standard cartridge puller but that (obviously) is no use here
    The frame is aluminum and the bearing races steel.
    Jul 2020
    Just in case anyone else encounters one of these. I ended up drilling some blocks of hardwood to make a simple puller. The longer piece of oak had a 1 1/4" hole drilled in it that was large enough for the bearing to pass through but small enough to engage with the lip of the frame around the bottom bracket . The smaller pieces of maple had small holes large enough for the square end of the bottom bracket spindle to pass through. I used the crank bolt and a larger diameter washer to spread the force across the blocks of wood. The bottom bracket spindle has a lip so tightening the crank bolt pulled the bearing from the frame. Repeated on each side.
    Attached Thumbnails Attached Thumbnails Help with Fisher Bottom Bracket Removal-img_8385.jpg
    artistic...
    Reputation: colker1's Avatar
    Do you have a mallet/ hammer?
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    Jul 2020
    Quote Originally Posted by colker1 View Post
    I'm always leery of reaching for a mallet with my old bikes. I didn't want to damage the spindle as that would leave me needing to shim a cassette in.
    The bearings are standard 6003-2rsh, cheap, and I was able to find them locally.
    I hope to press the new bearings in using some hardwood and clamps
  1. Threaded bottom bracket (2019 Stumpjumper): Want carbon crank with bottom bracket
    By rakerdeal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2020, 08:03 AM
  2. Replies: 5
    Last Post: 06-30-2017, 02:34 PM
  3. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  4. Replies: 3
    Last Post: 04-26-2016, 08:48 PM
  5. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
Members who have read this thread: 17
