Friction Shifter part question- Mtbr.com
Results 1 to 7 of 7
    Hey there guys, been riding my 83ish Ross and loving it. I do have one question. What is this ring on the top of the shifters for?
    Here's a quick shot of the whole bike a cleaned up. I do have the original seat but it kill the backside.
    ong
    ong is offline
    It tightens or loosens the action on the shifter. Too loose and it will slip; too tight and it will be difficult to shift. It basically determines how much friction your friction shifters are using!
    I assume turn right to make it tighter and left to make it looser?
    ong
    ong is offline
    Sure -- the effects are pretty obvious if you play with it a bit. Tweak it a bit, then shift and you can feel it getting looser or tighter.
    Stokeless Asshat
    Reputation: jeff's Avatar
    It also allows you to remove the shifter and adjust it's position on the perch. Go ahead and play with it. There's not much to break or lose with those.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Reputation: proto2000's Avatar
    There is a saying that goes; righty tighty, lefty loosey. Can't go wrong with thumb shifters.
    Too many bikes, and just enough time to ride them.
    Reputation: guitartreker's Avatar
    The ring flips up so you can adjust the tesion without using any tools.
    Wanted Shimano RD-AL11
