Fat Chance seat collar substitute- Mtbr.com
Results 1 to 11 of 11
    Unicycles are for clowns
    Feb 2005
    Wanted to know if the little rubber piece and stock collar is required, or if the Salsa Liplock will work in it's place- and if so what size? I believe the seatpost is 29.4mm so 30.6mm seat collar?
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    IIRC, the fat chance (at least the one I have) has an eyelet out the back of the seat tube that the clamp slides over. You may be able to use the salsa one, as long as it lines up with the eyelet.
    I think the collar on my is a DKG or something along those lines, BMXy.
    Plum
    This post is in 3B, three beers and it looks good eh!
    Schipperkes are cool.
    Reputation: banks's Avatar
    You can cut that tab off with no real damage to the bike and indoing so allows other collars to work.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    You're still around!?
    -eric-
    http://www.rumpfy.com
    Feb 2005
    Quote Originally Posted by Rumpfy
    Can you believe it!
    I get tired of the other forums talking about how fast or what a better rider they are or how they have more experience because they have lots of travel on their bike, a 29er, carbon wonder, etc, blah, blah, yeah. Pretty sure I know how to ride. However in this forum you can visit the past and have a laugh.
    Reputation: yo-Nate-y's Avatar
    I thought it was 31.8 but can't confirm (away from my bikes!)
    The original collars are DKG and they in fact still have some in stock. There is a thread on FatCogs right now about this very thing. The rubber is not required, but the clamps with and without it are slightly different (with= taller clamp and groove for the rubber ring).
    Somec is like the digital Zunow
    And this: http://www.youtube.com/watch?v=JD5h3y0a9AU
    Back home now-----they are indeed 31.8
    Feb 2005
    Cool, thanks again!
    Reputation: fat-tony's Avatar
    Quote Originally Posted by yo-Nate-y
    That green plastic gasket insert (rubber) sure does help to keep the crud and water out that will eventually rust out the bottom of your seat tube though..................at the BB.
    blah, blah, blah..........
    www.fatcogs.com
    Keep things well greased and pay attention to your dalliances on wet days and you should be fine though.
    Quote Originally Posted by fat-tony
    That collar contributes to FATs rusting out in the st.
    -Schmitty-
