Different Altek Lever Versions?- Mtbr.com
Results 1 to 5 of 5
    I'm Done
    Reputation: Durga's Avatar
    Feb 2005
    I read on here that Altek only made v-brake levers (which I'm not sure of). It seems they had at least two different models due to the main pivot location being slightly different:
    Different Altek Lever Versions?-altek2.jpgDifferent Altek Lever Versions?-altekbrakeleversredsilver6.jpg
    Does anyone know the various models that were offered, and what the primary differences are?
    Reputation: crank1979's Avatar
    Feb 2006
    They had a gripshift model and a trigger model that I remember. I had the GS model that I ran with Shimano triggers without any issues.
    I'm Done
    Feb 2005
    Quote Originally Posted by crank1979 View Post
    Interesting! I never knew of a "GS" model. So far I've only found mentions of BL-10, BL-20, & BL-25 models. The entry on Bikepro is:
    "ALTEK BL-20 standard or BL-25 with the V-brake pull ratio"
    I would guess the BL-10 model has a shorter lever? I'm not sure. Also not sure where the GS model fits in in all of this, and what distinguishing design features these different models have.
    Feb 2006
    BL-25 sounds right for what I had. I remember when I bought them through a magazine mailorder I had the choice of black or red, and I had to choose gripshift or trigger shifters.
    I choose red.
    They were great levers. I had them paired to Shimano DX v-brakes, because they were a red version of the LX brakes.
    They also did levers for the Magura HS brakes that looked awesome.
    edit: A quick google shows the BL-25, BL-15 and BL-40.
    No known cure
    Reputation: Vader's Avatar
    My favorite V lever. I'm not sure which model I have but they're on a single speed so it doesn't matter. The bend in the lever blade is the exact same as the Avid Black Ops levers. The Alteks have a wider blade and a better pivot. With the Avids I had to shim the slop out of them with disc brake caliper spacers.
    I had the Magura lever blades too.
    Attached Thumbnails Attached Thumbnails Different Altek Lever Versions?-img_20190121_155843087.jpg
    Ripping trails and tipping ales
  1. DT 350 Freehub Question - Are Boost Versions Different?
    By Averbuks in forum Wheels and Tires
    Last Post: 09-19-2016, 08:19 AM
  2. Monkeylite MX, different versions?
    By cooljavy in forum All Mountain
    Last Post: 06-09-2008, 10:50 AM
  3. Different Versions of Kenda Karma
    By butchc in forum 29er Bikes
    Last Post: 03-22-2006, 02:12 PM
  4. Altek brake lever question
    By kona1 in forum Vintage, Retro, Classic
    Last Post: 02-05-2006, 11:35 AM
  5. Altek lever blades 4sale...
    By Vader in forum Vintage, Retro, Classic
    Last Post: 10-16-2005, 09:42 PM
Members who have read this thread: 14
