Cooks Bros. Racing RSR Q-Factor/Bottom Bracket Question- Mtbr.com
Results 1 to 6 of 6
    underachiever
    Reputation: misterdangerpants's Avatar
    Oct 2007
    The Cooks Bros. Racing RSR is documented as having a Q-Factor of 167mm. Does anyone recall what bottom bracket length was used to determine this? Back in 1996, I used a 122.5mm TNT Ti BB on my RSRs but can't remember if that was the recommended width.
    Thanks in advance.
    Note: I should say that BikePro is the only place I was even able to find the Q-Factor measurement. They explained that they used a 111mm Campy bottom bracket to achieve their numbers. I can see using this width for a road bike, but certainly not for mountain applications.
    Reputation: laffeaux's Avatar
    I'm not sure what the Q-factor is, but can confirm that the Cook's cranks require a long BB spindle. With a 111mm spindle, the arms are likely to hit the chain stays.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    underachiever
    Oct 2007
    I recall something about 127mm being the default size for the RSR but again, it's been awhile.
    Last edited by misterdangerpants; 07-11-2014 at 12:10 PM. Reason: Removed graphic.
    lol I know what "q-factor" is. I don't know the "q-factor" of Cook cranks. I should have been more clear.
    underachiever
    Oct 2007
    Quote Originally Posted by laffeaux View Post
    I am long overdue for a new eyeglasses prescription....
    Quote Originally Posted by misterdangerpants View Post
    Thanks in advance.
    Did you ever find an answer to this? Because Campy bbs are ISO chances are the cranks went farther in than with a JIS bb..
  1. ASR-SL Bottom Bracket Question
    By creeker_1 in forum Yeti
    Last Post: 03-21-2013, 01:50 AM
  2. Bottom Bracket question
    By trufflepig in forum Eastern Canada
    Last Post: 12-07-2012, 12:36 PM
  3. Pugsley / Profile Racing bottom bracket modification
    By anthony.delorenzo in forum Fat bikes
    Last Post: 11-03-2012, 08:07 AM
  4. Replies: 35
    Last Post: 08-16-2012, 11:51 AM
  5. Bottom bracket question
    By sprknranger in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-01-2011, 03:40 PM
Members who have read this thread: 13
