Can older late 90's Magura HS22 use the newer ~2011+ EVO2 mounting system?- Mtbr.com
Results 1 to 3 of 3
    Reputation: DeoreDX's Avatar
    In the past I always ran a Conti XC Pro tire that was less than 2". Finding a good 26x2" tire is like finding hen's teeth nowadays. Going up to a 2.2+ would greatly expand my tire selection. The issue is my rear tire. With the HS22's old finger style mounting system I don't have much clearance for this 1.95" tire on my rear let alone a 2.2"+. I've run a 2.2 in the past and the rim has to stay 100% perfectly true or I get pretty significant tire rub on the brake mount finger.
    Does anyone know if the newer EVO 2 mount will work with the older splinned finger style HS22's?.
    Edit to say I flipped the Magural mounts upside down to get tires clearance and added a standard brake booster I had laying around. I didn't like running them this way because of the leverage of the brakes really flexed the frame this way but adding the booster knocked down the flex enough I'm OK with it.
    -DeoreDX
    No known cure
    Reputation: Vader's Avatar
    This is the guru who can answer any question.
    [email protected]
    Ripping trails and tipping ales
    Neo-Retro Forever
    No need - just flip the adjustable fingers down instead of up. I've run those with 2.35's since 1995.
  1. Magura HS22, HS33, etc...school me!
    By pint in forum Vintage, Retro, Classic
    Last Post: 10-30-2013, 10:52 AM
  2. magura hs-33 evo2 plates
    By jayssmtbde in forum Brake Time
    Last Post: 09-08-2008, 01:22 PM
  3. Replies: 3
    Last Post: 01-22-2008, 01:43 PM
  4. Magura HS33 Evo2 retrofit and other questions...
    By P.I.-SSer in forum Brake Time
    Last Post: 06-06-2007, 07:07 PM
  5. What to do with an older (late 90's) bike? Sell, convert, ?
    By TreeHouse in forum General Discussion
    Last Post: 05-18-2004, 08:55 AM
