Can I use "normal" brake cables?- Mtbr.com
    Reputation: CLASSTIMESAILER's Avatar
    Will regular/modern/not heavy duty brake cables cinch up safely on my BR-M730 cantis? I know I could try it but I'd rather know that someone has used the thinner stuff under hard use successfully.
    Jeff
    My '85 Cimarron and my '90 Alpina Team ARE mountain bikes.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    I can't see even the smallest issue with that, no.
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    Cool. Thanks. I can move forward with my project. I over thunk the difference between 1.6mm and 1.8mm brake cables and how effectively they'd be clamped in place.
    Feb 2005
    Yep, two plates can clamp, more or less, depending on how thick whatever's in between them, is.
  1. Replies: 8
    Last Post: 10-29-2016, 07:20 AM
  2. NEW (recently released) Gore RideOn cables vs. Drycable.com cables.
    By lalittle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-31-2007, 09:32 AM
  3. Use "Low-Normal" RD w/ "High-Normal" Shifter??
    By mas4444 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2007, 10:30 AM
  4. Cables, Cables and More Cables
    By Ultra Magnus in forum Weight Weenies
    Last Post: 01-21-2005, 10:28 PM
  5. Are cables just cables or...
    By CrashTheDOG in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2004, 01:01 PM
