Results 1 to 5 of 5
    Best practices for cantilever pad setup. Goat got some new stoppers
    Finally removed all evidence of V-brakes from the Goat. Added some black Suntour brakes & hangers to match the rest of the build. Looks much better now.
    I would like some advice on setting up the brakes & pads. Any best practices out there to easily set toe & all that would be much appreciated.
    Attached Thumbnails Attached Thumbnails Best practices for cantilever pad setup. Goat got some new stoppers-new-suntour-brakes-hangers-1.jpg
    83 Ritchey Everest
    88 Mountain Goat Whiskeytown Racer
    95 Bianchi Mega Tube ti
    2012 Ibis Mojo HD
    2015 Kona Process 153
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    See if you can find Keith Bontrages article about cantilever setup. I did way back and was able to use 1 finger. Don't recall the deets now.
    Sent from my SM-G935S using Tapatalk
    I got some bad ideas in my head.
    83 Ritchey Everest
    2012 Ibis Mojo HD
    No known cure
    Reputation: Vader's Avatar
    Use a business card on the rear of the pad to set toe in. Some pads, like Kool Stop have a slight ramp on the rear to make it easier. Here's another resource.
    https://www.sheldonbrown.com/cantilever-geometry.html
    Ripping trails and tipping ales
    Reputation: mainlyfats's Avatar
    Getting the cables right - de-burred and properly round - plays a big part in this. Sharp cutters are key.
    Assuring that the brakes are a good fit on the posts is also important. Filing a post where necessary can result in less play and better, more positive, contact.
    Last tip I have is using a brake that has no tension you are setting the pad. With internal springs (like your Suntours), try taking the spring out until the pad is set just right. With Paul brakes (my fav) or old post-mounts, the disengagement is easy and makes perfect toe and placement easy.
  1. Going Tubeless - can I get some advice on best practices?
    By squashyo in forum California - Norcal
    Last Post: 09-06-2014, 12:02 AM
  2. Replies: 2
    Last Post: 10-30-2012, 01:05 PM
  3. Cargo bike stoppers :)
    By alanm in forum Brake Time
    Last Post: 04-14-2012, 06:43 AM
  4. Some new stoppers for Cedric Gracia
    By Perigeum Development in forum Downhill - Freeride
    Last Post: 04-17-2006, 10:36 PM
  5. X-Post New stoppers for Cedric Gracia...
    By Perigeum Development in forum Brake Time
    Last Post: 04-17-2006, 03:56 PM
Members who have read this thread: 36
