Best Method to DeGunk ST-M091 Levers- Mtbr.com
Results 1 to 7 of 7
    Reputation: CLASSTIMESAILER's Avatar
    I have a new-to-me 1990 Univega Team Alpina with the full XT group. I briefly put it on the stand and the shifters are sluggish. What is the best way to get them to shift smoothly? Remove the cover and use WD-40? or is there more I should do? And what should I use for lube after they shift smoothly?
    Jeff
    Feb 2013
    I've had good luck with tri-flow. If they're really bad I use a plastic-safe electronics cleaner/degreaser, and follow up with tri-flow, I've brought shifters that don't engage at all back to life with that cleaner and tri-flow.
    Those are XTii 7/8sp thumbs? - I think there's holes underneath so you shouldn't have to disassemble at all.
    Make sure to lube the cables first (I'm sure you know that), especially the housing nearest the rear der. You probably know this too: on the stand shift to the biggest rear cog in the rear, without turning the crank shift to the smallest rear cog, that will give you enough slack to pull the cable housings clear of the braze-ons, and you can slide the housings off from where they normally sit, wipe with a cloth/paper towel and re-lube with tri-flow. I've also used liquid/graphite lock-lube for cables, that stuff is so viscous it will flow down into the cable/housing quite well.
    Post a pic when you can, sounds like a neat bike.
    skidding is the signature of the novice; learn how to use your brakes.
    These are the Push Push levers and they barely spring back. Here is the bike. I donít think it has ever been off road. Seems original except for the saddle. When I get a chance to do a proper tune up, Iíll post more pics.
    Best Method to DeGunk ST-M091 Levers-594bedaf-de71-47c4-9b96-7ef24103524d.jpg
    Best luck I've had with getting rid of the stiction for good is an hours long soak in rubbing alcohol followed by a long rinse with hot water directly into the cable hole. (all done off bike with cables removed)
    Tri Flow tends to get sticky after a long time, a lighter not wax lube like Wd40 would probably do best or maybe a gun lube.
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2019 Kona Process 153 CR 29
    Dec 2015
    Best way is to disassemble them, I have done it on a couple of my bikes but it can be tricky getting them back together. Heavy dose of WD40 will sometimes get those spring loaded prongs to free up and respond.
    Jun 2016
    If you take them apart, take lots of photos. I replaced the plastic cable holder in one successfully a couple of years ago. Yet, I was confident last night and took apart one that was stuck and have 2/3 of it back together before getting stuck...and I didn't take good photos.
    I ran out of time and plan to finish it over the next couple of days. I'll probably look at an assembled one to figure out the last 3-4 parts I have.
    monster member
    Reputation: Wheelspeed's Avatar
    I'm a bit of a simpleton but I've had plenty of slowish, sticky levers and I just pull the hoods back or pull a cover off, and blast it with WD-40. That stuff has become so popular because it's just freakin' awesome. On my old road bike, I don't even know what I'm aiming at but just pull the hood back and blast it around.
    That said, those special cable-lube tools are also awesome for freshening old cables. I don't know if you mean our shift levers move slowly with or without the cables attached.
    Have fun!
  1. Best method to clean a Fatboy after some sandy/salty beach riding
    By Father Guzzi Obrian in forum Fat bikes
    Last Post: 02-08-2015, 04:56 PM
  2. Replies: 4
    Last Post: 04-08-2014, 10:26 AM
  3. Replies: 19
    Last Post: 05-10-2013, 12:17 PM
  4. The best method to carry a bike on your back
    By stubs in forum General Discussion
    Last Post: 02-17-2011, 08:01 AM
  5. st-m091 opinions
    By XR4TI in forum Vintage, Retro, Classic
    Last Post: 08-03-2007, 02:04 PM
