Any VRC frames out there with long TTs?- Mtbr.com
Results 1 to 15 of 15
    No known cure
    Reputation: Vader's Avatar
    I have a pile of parts looking for a mid 90's 18-19 inch steel frame but I need a longish top tube. I'm kind of a knuckle dragger and my last two custom frames have 24 inch top tubes. Anything I should be specificaly searching for? I think a 23.5 inch TT with a 100mm stem would work. It doesn't have to be anything exotic, but should have nice tubing. Thanks
    Ripping trails and tipping ales
    gobsmacked Moderator
    I know this answer! ooo ooo!
    Yeti.
    Stokeless Asshat
    Reputation: jeff's Avatar
    I've heard of an Otis Guy with a reeeeeaaaaly long TT.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    artistic...
    Reputation: colker1's Avatar
    mid 90s? Gary Fisher.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    Neo-Retro Forever
    Why not run a 23 inch top tube with a 125mm stem? The handling of early-mid 90's bikes are based on longer stems anyhow...
    Reputation: Boy named SSue's Avatar
    Quote Originally Posted by colker1 View Post
    For that matter, didn't Barracuda do the same thing first?
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Nevil
    MTBR Posting Guidelines
    calories>electrons
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Quote Originally Posted by jeff View Post
    Ya, but the HT angle and stem offset that 25" TT.
    -eric-
    http://www.rumpfy.com
    18" WTB Phoenix.....pretty long setup. 2nd Nevil as well....the devil worked a really long top tube.
    Looking for/WTB : Grove Innovations Assault Fork, Grove Innovation Hammerhead Stem or Hothead Bar Stem
    Reputation: Bigfoot's Avatar
    Iron Horse. The MT700 A-frames were lonnnnng.
    "Yeah, Humboldt County is way the %#@* up there, but worth it!"
    Reputation: laffeaux's Avatar
    On a bike with a sloping top tube, buy the next larger frame size and the TT is longer.
    I'm not sure that any 1990's frame was intended to be run with a 100mm stem. With TTs the length that you're interested in 120-150mm was the norm at the time for stem length.
    Also, pay attention to seat tube angle. A 23" top tube a frame with a 74 degree STA is a longer bike than a 23" top tube on a frame with a 72 degree STA.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Feb 2006
    Quote Originally Posted by laffeaux View Post
    That seems counter to what I would of thought. Would not a 74 degree STA be more vertical bringing the seat closer not farther to the stem?
    Quote Originally Posted by Fred Smedley View Post
    The saddle should be in the same position relative to the bottom bracket regardless of seat tube angle. So with a steeper STA the saddle needs to be moved backwards relative to the seat tube by either having the saddle slid backwards on it's rails or by using a seat post with more offset. The steeper your STA, the further rearward the saddle must be moved to maintain your position on the bike.
    Slacker seat tube angles put more of the top tube length under the saddle instead of in front of the saddle.
    No known cure
    I had a Ventana full sus built last year with a 74* STA and a 24"TT. with a 70mm stem. The other frame has a 72* STA and 24" TT with a 50mm stem. Both are perfect.
    Thanks for all the input. I know there are long TT production frames out there, like the first double diamond Alpinestars CR frames. My 1994 had a 23.4 TT and OX 3 tubing.
    I'm trying to stay away from anything desirable and sought after due to costs, and because it will be a winter beater. I'll probably end up running a longer stem and keep an eye out for a sloping TT Rocky, Voodoo or something similar.
    A 1991 20" Kona Explosif had a 24" effective top tube, according to the catalogue. I know 20" isn't 18 or 19", but the sloping top tube might still give you enough stand over. Just my 0.02 $
  1. Frames with long TT and low SO?
    By LBIkid in forum 29er Bikes
    Last Post: 07-31-2009, 06:32 AM
  2. very long dj frames
    By Squatch_ in forum Urban/DJ/Park
    Last Post: 07-14-2008, 04:30 PM
  3. Hardtail frames - after a long TT
    By womble in forum General Discussion
    Last Post: 04-09-2007, 11:31 PM
  4. Very Long Q&A about FRAMES
    By bikesdirect in forum General Discussion
    Last Post: 11-13-2006, 06:52 AM
  5. 3 frames = 1 Blur (long)
    By Grampa in forum Santa Cruz
    Last Post: 07-05-2004, 09:41 AM
