1991 Schwinn Sierra MOS- Mtbr.com
Results 1 to 35 of 35
    I just got this a couple weeks ago, got it cleaned up and tuned up a bit, and figured I should post up before parts start arriving this afternoon.
    Frame: Schwinn M.O.S. Tri-Butted (Cr-Mo) tubes w/ oversize head, seat and chainstays, 16.7" G-Force chainstays
    Fork: Tange/Schwinn G-Force Cr-Mo w/ 800mm radius. OS Blades
    Rims: Ritchey Vantage 26"
    Hubs: Shimano Exage 400LX
    Quick Release: Shimano 400LX
    Tires: (Factory) Schwinn KOM skinwall (HAD Mismatched) Kenda Kinetic rear Tioga Psycho in Front... (NOW) Kenda Kross 26x1.95
    Pedals: (Factory) "MTB Steel w/ Toe Jammer clips.
    Crank: Shimano 400LX, Biopace Chainrings (28/38/48T)
    Chain: Factory ? (Should I buy a new one??)
    Freewheel: Shimano HyperGlide Cassette, 7-Speed, 13-30T
    Front Derailleur: Shimano Exage 400LX HyperGlide, SIS
    Rear Derailleur: Shimano Exage 400LX HyperGlide, SIS
    Shifters: (Factory) Shimano 500LX.. front was broken. (NOW) Shimano Altus ST-EF50.
    Handlebars: (Factory) Schwinn 25.4 Team Issue Cr-Mo (flat w/ 6* bend) (NOW) Easton EA30 25.4 1.5" Riser (I wasn't comfortable with the flat bars.. short arms I guess.. HAHA)
    Grips: (Factory) Foam. (bad condition.. 20 yrs old LOL) (NOW) Schwinn cheapies from Walmart. Sette Type-S Lock on set on order
    Stem: Schwinn M.O.S. Team Issue Cr-Mo, Internal cable guide.
    Headset: Tioga Avenger OS, Sealed.
    Brake set: Shimano 500LX-SLR
    Brake levers: Integrated w/ Shimano ST-EF50 Shifters
    Saddle: Schwinn MTB, Emerald Skin
    Seat Post: DP-K, 350mm, Schwinn QR-Pin
    Paint: Red w/ Black Spider
    Size: 17" (I am only 5'6")
    Schwinn Catalog....
    Pics... Condition when I bought it....
    And after a bit of a bath.....
    It's nothing special.. But It's a great fit, has already lasted 20 years, rides great, and I like it... I dont do any serious off road riding at all (obviously) and keep to the streets, and some 24 miles of paths in my neighborhood... Thus, the slick tires I ordered... I bought some paints to fix the scars on the frame, red, black and silver to touch up everything... I may tear it all down, and redo the whole frame... I have a custom vinyl graphics guy who could make me all new stickers to match the factory stuff... I'm really enjoying riding, and have already learned alot about repairs and adjustments and how to maintain a bike... I look forward to learning much more, and plan to upgrade this bike to the fullest I can over the summer, and will buy a new "good" bike once work picks back up hopefully next fall..
    I'll update this as I change the bike, If there is any interest at all..
    73% of all statistics are made up.
    Hi.
    Reputation: jtmartino's Avatar
    "Into serious racing? What about adrenalin?"
    LOL.
    Marketing jabs aside, I like restoration projects well-documented with pics. Keep 'em coming .
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    Those were decent bikes at the time. I sold them new and sold one to my roommate in college. He rode it pretty hard and it held up well for him. Thanks for the photos.
    I bought a bike just like yours a couple weeks ago. Mine has a taller frame and has had the wheels changed from stock, but is pretty much the same.
    The problem that caused the original owner to sell it is that the chain "skips" in higher gears. He had replaced the chain and RD trying to fix it. When I bought it, I thought it might need a new cassette, but after cleaning the crud and sticks out, and closer inspection, found that it appears to be OK. However, I did find that the front chain rings are in terrible shape and appear to be the problem. The teeth are worn badly, and the rings are very much egg-shaped!
    Once I get those rings replaced, it should be in good shape. The best thing about the purchase is that the previous owner just put new Vuelta Zero Lite wheels on the bike.
    Reputation: galleta loco's Avatar
    Nice pics and reportkeep it up!!!
    the front chainrings are supposed to be egg shaped on this bike. It's the "Biopace" thing.. it is supposed to be optimized for maximum leverage. Mine are worn too.. and i am getting a "click" each time around with the pedals... Im not slipping any gears yet so i'm holding off replacing anything else until it breaks..
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Fitz, you should probably check the hanger alignment too
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    gobsmacked Moderator
    biopace is making a comeback!
    Quote Originally Posted by DrFizz2k1 View Post
    Oh, I had no clue. Makes sense. Well, hopefully it is just the worn teeth. Thanks for the info!
    Quote Originally Posted by wv_bob View Post
    I've spent some time adjusting and looking at alignment. I think this is OK, but I won't try to act like I know what I'm doing with bikes.
    Took a pic of the bike while home for lunch.
    The gear skip problem only happens when I'm in any of the four smaller gears of the cassette (with the front on largest gear), or if I use the middle or small gear on the front with any rear gear. If I stick to the large gear up front and the larger three in the rear, it doesn't do it.
    Attached Thumbnails Attached Thumbnails 1991 Schwinn Sierra MOS-img-20110829-00176.jpg
    Shoot a pic of the front rings and the rear cassette.
    It looks to be a bit newer than mine.. certainly is a MUCH taller frame.. LOL.. I'm only 5'6.. scored when i found mine the size i did.. HAHA.
    I shot this one at lunch too, but didn't get a close-up of the cassette. Can do that later.
    This is the height I was looking for since I'm 6'1". Stand over height is about 33-1/2".
    Thanks.
    Attached Thumbnails Attached Thumbnails 1991 Schwinn Sierra MOS-img-20110829-00177.jpg
    Here are some pictures of the rear cassette, and the chain rings. Let me know if you see anything wrong. Thanks.
    Attached Thumbnails Attached Thumbnails 1991 Schwinn Sierra MOS-img-20110830-00178.jpg
    Hi.
    The skipping is likely coming from the cassette. The gears look pretty worn out. Get a new cassette and make sure your chain isn't too stretched out. Nashbar sells 7 speed cassettes for cheap:
    Nashbar 7-Speed Mountain Cassette - Normal Shipping Ground
    DrFizz...
    I couldn't send a PM so here's a copy of the message I tried to send you.
    Hey, I know that you posted about your bike long ago, but I was wondering if you ever got the decals that you mentioned in one of your posts? I just purchased a 1990 Schwinn Sierra MOS and I want to replace all the decals after I strip it and re-paint it. I've done a google search for an online shop that has the decals in stock or that can reproduce them and I've had no luck. Any information helps. Thanks.
    Actually what I did was... because they weren't stickers.. I wanted to maintain the "vintage" spec.. I bought some paints.. (Testors) and hand painted the scratched parts back on. Luckily the color matched pretty good. I can link you to a guy who can do the vinyl stickers though if you like...
    Stickers guy
    I'll snap some recent pics in the next day or two, weather permitting...
    Sorry I'm not more help..
    DFA
    DFA is offline
    Reputation: DFA's Avatar
    I have a soft spot for the old Schwinns. Bought a Paramount PDG 70 back in 91. Stripped the parts off it to build my the Edge up in 93 and sold the frameset. Found another one on Kijiji in the spring locally and scooped it up. Still had the reflectors on it.
    Jun 2012
    I had a Mongoose, my first mountain bike, from the same year. Nearly identical red paint job with black swirl splatters- the early 90's were crazy like that. Of course my frame was made from straight gauge gas pipe and the bike weighed 35lbs. I still rode it on the trails somehow. Thanks for the photos, it brought back good memories of my early days.
    Nice bike, I would not only replace the cassette and middle chainring, I would also replace the chain. Chains are inexpensive unlike cassettes and chain rings. If you ride often replace the chain each year, your cassette will last much longer!
    Cheers
    Hey guys...so as I posted earlier, I just got my hands on a '90 Schwinn Sierra MOS. I stopped by this house in which the family always has a new batch of old beaters that they tune and sell off. I asked the guy if they ever run into the original components that the Sierra MOS came with, or upgrades and he recommended that I not do anything with the bike. He said that parts are hard to come by, the bike wasn't that great in 1990 and it's not that great now, he also said that many new components might not fit the old frame. He added that it'll be expensive to rebuild it into something decent and that I would never get my money back if I try to sell it off just because of the "Schwinn" on it.
    I knew I didn't buy a diamond in the rough, but is he right? Also, the wife and I already have mountain bikes so I don't necessarily need the Schwinn if it's crap as this guy made it out to be...I liked the appeal of a semi-old bike of good "quality". Should I chop it and make a homemade tandem bike with it instead?
    KEEP IT!!!!!!! A Chrom-moly double butted, quality steel frame is strong, lively and responsive. The components look good as well, touch-up the paint and overhaul all bearings and you will have a great bike.
    Cheers
    Cool bike---do it!!
    Lookin good!
    i also have a sierra. it almost all original. bought it when i was up in Connecticut a truck load of years ago. may have 20 rides on it? just had it tuned a couple weeks ago. it has 4130 chrom moly on it, whatever that means?
    A high quality, light butted alloy steel that when built into a bicycle frame is resilient, responsive and lively, unlike aluminum and to some extent carbon fiber that are often more harsher riding than steel frames.
    Great stuff man
    I remember this being a tank. Get some sweet air on it and post some gnarly pics!!!
    Reputation: JPBakerIII's Avatar
    Mar 2012
    I have a 1990 Schwinn Sierra MOS. I have changed out the shifters, seat, chain, and of course, tires. I have some real nice new mountain bikes that are better suited for dirt and trails but the Sierra is still a good bike to tool around the neighborhood on. Probably won't ever be worth a fortune, but it is very dependable.
    I had one of these back in the day, it was my first mtb. I have such fond memories of that bike. Thanks for posting this. The pics are great!
    Here's mine, 20 years ago:
    Here she is..my latest find on CL: not sure of the year, but a absolute steal at $70. Only negative is a 13 yo kid (it was his dads) tried to peel off some of the name on the top tube. Everything is original, except for the tires that were just replaced. It's a 21" frame and loved my initial ride. Swapped out the seat for my WTB.
    Attached Thumbnails Attached Thumbnails 1991 Schwinn Sierra MOS-100_0647e.jpg
    I like big bars and I cannot lie
    Oct 2020
    1991 Schwinn Sierra MOS - Mine still going strong...
    Admin - please delete.
    Oct 2020
    Also have a 1991 Schwinn Sierra MOS - [Q] Upgrade or should I drop $$ on a new bike?
    Oct 2020
    1991 Schwinn Sierra MOS. [Q] Upgrade or Spend $$ for new MTB?
    Oct 2020
    I have this same bike that I bought in 1991 while in grad school and i'm still riding it. Changed the tires and basically kept it pretty clean. Still rides smoothly and shifts great. It is a little heavy compared to modern mountain bikes. I've been riding it a little more lately and was wondering what minor upgrades I could make to it to enhance the experience. I mainly ride on paved surfaces, gravel trails, and occasionally something aggressive (on the east coast). If I wanted to upgrade the original Shimano 400LX STI 7-speed shifters, what's the best replacement options? Are the older Deore 7-speed shifters still haunting Ebay?
    Also - I've been toying with the idea of actually buying something newer and lighter. This has my attention right now but I'd wait until all the COVID-19 bike buying subsides (hopefully next year). Thanks.
Members who have read this thread: 15
