Zeus shock length and stroke?- Mtbr.com
Results 1 to 8 of 8
    No known cure
    Reputation: Vader's Avatar
    Anyone know the measurements? Thanks.
    Ripping trails and tipping ales
    200X57 mm or 7&7/8X2.25"
    just a guess, but 99% sure
    breezy shade
    No known cure
    Quote Originally Posted by nhodge View Post
    I'm hoping it's 7.87x2.25
    Quote Originally Posted by Vader View Post
    which is 7&7/8
    breezy shade
    No known cure
    which is 7&7/8
    If it works out, I can use my CCDB with a Ti spring and save some cash on a new frame. With the trade in program, I'll save 30% which is really 20% after California takes a bite.
    sounds like a good plan. have you confirmed w/ Sherwood that a coil is compatible w/ the current Zeus?
    breezy shade
    No known cure
    On my previous gen Ciclon, clearance between the seat tube and coil is 5/8ths at the bottom/tightest with a 450# spring.
    i was thinking more of the leverage curve instead of the physical fit. might be worth checking w/ Ventana. not all of their bikes work w/ coil shocks
    breezy shade
  1. Replies: 29
    Last Post: 10-31-2019, 06:54 PM
  2. Replies: 1
    Last Post: 04-04-2007, 03:15 PM
  3. 2.75 shock stroke change to 2.5 stroke
    By falcon171 in forum Downhill - Freeride
    Last Post: 05-26-2006, 02:48 PM
  4. 2" stroke Manitou spring on 2" stroke Manitou shock?
    By Enduro_506 in forum Shocks and Suspension
    Last Post: 05-05-2006, 02:23 PM
  5. using a 2.25" stroke shock on a frame intended for a 2"stroke?
    By ATOMICned in forum Shocks and Suspension
    Last Post: 04-08-2006, 04:30 AM
