El Commandante frame weight?- Mtbr.com
Results 1 to 6 of 6
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    Curious what people's El Comms have weighed in at. Just received one that's 5 lb 1 oz with HS cups pressed in (20"), considerably more than expected.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    But keep in mind, that's a hard tail you can ride like you stole it and will hold up to the abuse. I have a XL 650B frame weight was 5 lbs 7 oz. It's looking like it will build out at around 26 lbs with a RS Revelation 120mm and XT Build Kit.
    Sep 2004
    Yes, it's obviously sturdy construction. More of an issue that the estimated weight was 4.1 lbs, so curious if this is an outlier due to mild customization. 4lb aluminum hardtails can be plenty sturdy too.
    Quote Originally Posted by ACree View Post
    It's not clearly obvious, since you didn't first state that you had a customize frame.
    Sep 2004
    Ventana = sturdy. IMO the minor tweaks to geometry would have less impact than size (added to original post).
    Quote Originally Posted by mtnbiker4life View Post
    So do carbon frames. I own a Ventana El Padrino and it is a great bike. Really enjoy it but have found I enjoy the feeling of carbon more. Wish Ventana would make the jump to carbon.
  1. el commandante cyclocross
    By rootsandrocks in forum Ventana
    Last Post: 12-10-2012, 11:33 AM
  2. Considering a El Commandante
    By SlowPokePete in forum Ventana
    Last Post: 10-06-2012, 08:55 AM
  3. Tire Clearance on El Commandante
    By Brewtality in forum Ventana
    Last Post: 12-31-2011, 05:35 PM
  4. El Commandante Ultimate
    Last Post: 05-15-2011, 11:03 PM
  5. 2011 Jekyll Carbon Frame Weight vs. Alloy Frame Weight
    By freerideordie in forum Cannondale
    Last Post: 02-25-2011, 09:31 PM
