Results 1 to 10 of 10
    Feb 2018
    Rear 10 x 135mm to Thru Axle Conversion
    I ride a 2014 Transition BLT with a 10 x 135mm rear qr axle. Is there any way to convert this to a thru axle for a little bit of extra stiffness and to prevent it from loosening when I have hard landings? I'm planning on purchasing new wheels so I decided now would be the time to think about this problem.
    Any help is appreciated,
    What year is your camber and are you looking to stick with 135 or go to 142?
    I have a like-new Roval Control Trail 29 alloy-rim wheelset with 142, 12 mm rear thru axle that I would like to convert to 135 QR.
    Any idea if we could swap end caps (and probably axles) and both end up with what we want? Hub appears to be DT Swiss but It's not explicitly labeled so I can't say for sure.
    It seems like end caps are available for conversion from 135 to 142 but not the reverse.
    Mudhorse
    Reputation: Grassington's Avatar
    Jun 2017
    I've just done a rear 135 mm QR to thru axle conversion, and not only was it fairly painless it's stiffened up my frame a treat - the cornering is noticeably sharper and it feels like more of my pedalling effort is going into moving the bike forward. All I did was change the endcaps on the Hope Pro4 hub from QR to 10 mm thru axle, and fitted this DT Swiss 10 mm thru axle. If you're lucky then your hub model will have interchangeable end caps, otherwise it's a new wheel.
    Quote Originally Posted by jdave5917
    It's theoretically possible, but would involve the hub manufacturers offering 142 endcaps for a 10 mm axle (142 hubs are 12 mm). I guess there's not enough demand for this as not many people need to fit a 142 wheel into a 135 frame.
    Hose me down till the water runs clear.
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by mrjwoj View Post
    You simply need a hub that can convert to 10mm TA, and a DT Swiss RWS axle. Hubs like Hope, Bitex, AC, come to mind. (most high end hubs have a conversion kit). If your on a budget, just get a Bitex with 10mm and re-lace the rear wheel.
    Some hubs use end caps, others require a conversion kit, aka new axle. Hadley also makes a bolt on rear axle as an alternative to the DT.
    It is a better setup than a QR, but you probably won't notice much of a difference.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Is it cup and cone bearings? Possible to just replace the qr with a solid steel axle and axle nuts?
    Feb 2018
    "What year is your camber and are you looking to stick with 135 or go to 142?
    It seems like end caps are available for conversion from 135 to 142 but not the reverse."
    I think I will be sticking with 135, Just a thru axle.
    Feb 2018
    Quote Originally Posted by Grassington View Post
    Feb 2018
    Quote Originally Posted by leeboh View Post
    Not sure, I will have to check.
    Feb 2018
    Quote Originally Posted by *OneSpeed* View Post
    I was planning on new hope hubs anyways, thanks for the info!
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Easy-peazy on a Hope. My Single speed wheels are running Hope hubs and the rear is 10x135 Thru-bolt. I'm using the DT Swiss RWS axle, as well.
  1. Anyone Make a Budget Frame Thru Axle 135mm rear?
    By OnThaCouch in forum 29er Bikes
    Last Post: 06-17-2014, 06:28 PM
  2. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  3. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
  4. Will this convert a 142mm thru axle to a regular 135mm QR?
    By Quinner in forum General Discussion
    Last Post: 01-25-2012, 09:09 PM
  5. 135mm x 10mm QR vs 10mm Thru Axle
    By Cusco in forum Wheels and Tires
    Last Post: 09-24-2011, 09:18 AM
Members who have read this thread: 18
