XCE Brake Setup- Mtbr.com
Results 1 to 8 of 8
Thread: XCE Brake Setup
    XCE Brake Setup
    Setting up a new XCE. The cable guides are on the bottom of the top tude. All three are the same caliber, ie there is not one with a wider hole for the rear brake line. What should I do to remedy?
    I had mine drilled out.
    Quote Originally Posted by mastakilla
    Not too tough to do. The only hassle is that you need to disassemble your brake to get it on/off the frame.
    Dave
    mtbr platinum member
    Reputation: bikerx40's Avatar
    Drilling out the brake stops is the way to go. Use a Dremel and some small files.
    I stopped driving my bike into my garage - I'm now protected with Roof Rack Ranger app for my iPhone.
    You can actually drill the stops through for the hose, but also make clearance on the slot on the top to snap the cable in place so you don't have to remove and refit the ends to slide it though. I did just this on my Burner and it worked very well.
    That's a good idea.
    Quote Originally Posted by Jerk_Chicken
    Did you have to fasten the hose down or did you make it just big enough to squeeze through?
    Dave
    Can Tree Member
    Reputation: Dad Man Walking's Avatar
    Sep 2004
    Problem Solvers Brake Line Guides
    http://www.jensonusa.com/store/produ...ne+Guides.aspx
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
    Quote Originally Posted by MightySchmoePong
    Dave
    The latter and never had a hose come free on its own.
    Am not, had mine removed.
    Reputation: markz06's Avatar
    Sep 2004
    Problem Solvers.
    I used the problem solvers with no problems.
    You want to ride behind someone who does something that?
    770-271-9506
