Where to source DHR needle bearing shaft?
My 06 DHR has been developing play between the rocker and the dogbone. I pulled it apart, and one of the bearings was seized and the bearing shaft is badly scored.
I went to Turner's site, and see that they do not include these bearing shafts in the rebuild kit.
http://turnerbikes.com/catalog/produ...products_id=34
Does anyone know where these are available? I guess I should bust out the calipers and see what I can find on McMaster.
Call Greg at Turner. They have them. I had some pretty bad shafts that seemed shot, but worked fine when cleaned up w/steel wool and new bearings.
- You may not post replies
- You may not edit your posts
Forum Rules
