Results 1 to 11 of 11
    Reputation: DirtJersey's Avatar
    Aug 2005
    Turner Sultan 27.5+ conversion question
    Can anyone provide some specs on their conversion
    rim size
    tires
    any other changes
    did BB height change
    Considering this for my 2014 Sultan
    Using Nextie 40mm OD rims, NN 2.8 on the rear, 3.0 FBN on the front, Fox 36/150 fork and the Turner rear shock offset eyelet the BB came out exactly on spec.
    Aug 2005
    can I ask what is the "offset eyelet"? something I need to change
    Thanks for the info!
    Aug 2005
    awesome Thank you
    Reputation: Bullit_cn's Avatar
    Anyone can confirm if a NN2.8 on a 45ID rim would still fit?
    When trails gets tougher, Just stand up and deliver.
    Wicketed
    Reputation: swan lee's Avatar
    Interested to hear how much clearance you have in the rear stays...I got some tyre rub at full compression with offset bushings and a 2.35 29er Hans Dampf....I fancy giving the 27.5 conversion a try, but I don't want to spend s on new wheels if the bushing conversion is going to cause the tyre to begin scraping its way through the seat-tube!!
    'I've got a bike, you can ride it if you like. It's got a basket, a bell that rings, and things to make it look good' - Syd B
    Well a 2.8NN mounted on a 38mm(31.6mm inside width) wide LB rims fit with around 6mm clearance on the chainstay and about 10mm on the seatstay on each sides.
    So I am wondering how much wider would it be if mounted on a 45mm Inside rim..
    Here's the picture,
    Quote Originally Posted by swan lee View Post
    Plenty of clearance on the seatube actually.
    I measured my current 29 wheels with 2.2 Ground Control and the height is exactly at 29"(740mm) while the 27.5x2.8 Nobbly Nic measure around 28.5".
    Wicketed
    Cheers for the info bullit_cn!
  1. turner sultan?
    By willandchar in forum 29er Bikes
    Last Post: 05-18-2016, 09:38 AM
  2. Replies: 0
    Last Post: 07-05-2013, 01:39 PM
  3. Turner DW Sultan Mod?
    By jncarpenter in forum Fat bikes
    Last Post: 10-15-2012, 04:14 PM
  4. My Turner Sultan
    By doublezero in forum Turner
    Last Post: 05-23-2012, 06:41 AM
  5. Turner Sultan...No BOB!
    By voodood-jab in forum Turner
    Last Post: 02-15-2011, 10:17 AM
