Ti Spring?- Mtbr.com
Results 1 to 8 of 8
Thread: Ti Spring?
    Rides Uphill Slow
    Reputation: The Hookler's Avatar
    Ti Spring?
    I'm thinking of putting a Ti spring on my 06 RFX. I have a 600lb steel spring that works well for my riding sytle and weight. Does anyone know what lb Ti spring would be close to a 600lb steel spring? It will be going on a Fox DHX.
    Also has anyone ever used a Ti spring from these guys...
    http://www.diverse-mfg.com/mtb/titan...ockspring.html
    who doesn't like pictures...last weekends ride
    I'm here for the downhill
    Hi mate the spring rate would be the same for ti as steel
    Hookler, I just put a DSP ti spring on my DW 5 Spot, the rate was the same as the steel spring. They shipped it out the same day.
    Rides Uphill Slow
    Quote Originally Posted by cheb
    good to hear they were speedy.
    Thanks for the heads up guys on the spring rate.
    Reputation: hardboiled's Avatar
    Cheb, are you running a Fox shock? Is there any play with the DSP spring on the shock? I read a review of the DSP springs that said there was play with Fox shocks, although it supposedly doesn't affect anything. So curious how yours feels. Thx.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Quote Originally Posted by The Hookler
    Before you pony up the dough on a Ti spring, swing by a MX shop and get them to rate your Fox coil. Fox coils run a tolerance of +/- 15%, which for a 600lb spring would mean it could be anywhere between 510 and 690lbs.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Rides Uphill Slow
    Quote Originally Posted by MK_
    _MK
    I had no idea. Good call on the MX shop.
    lazy piston
    Mar 2006
    Did you weigh the spring? Was the claimed weight (as listed on their site) accurate?
