sram xx cranks + 2008 nitrous?- Mtbr.com
Results 1 to 6 of 6
    anyone know if the chainstays of a 2008 nitrous are narrow enough for the lower Q factor XX crankset?
    thanks.
    mtb addict
    Reputation: AustinBiker's Avatar
    I have the same question about a Titus RacerX 29er. Anyone have a definitive source to refer to?
    Reputation: protocol_droid's Avatar
    2008 nitrous?
    3po armorless, the first weight weenie.
    Reputation: bikesinmud's Avatar
    Dec 2005
    I'd also like to stick the XX on my new flux dw. I've got a set of 2x9 Rotor Agilis cranks with a q-factor of 163mm. About 3-4mm clearance on each side of the rear triangle. XTR 970's have about 5-6mm room on each side. Anyone know the Q of the XX?
    Reputation: mrhand's Avatar
    The first XX crankset to come out will be Q factor of 156. Word on the street is that we'll see two more versions --164 and 166 to allow for a wider range of compatibility amongst frame models.
    mad aussie
    Reputation: Flying Wombat's Avatar
    Its the chainline that is important in clearance, not the q factor which is the distance between the crank ends. The SRAM XX has a 49.5mm chainline, Shimano has a 50mm chainline, so you should be able to check clearance by running your big chainring in the middle chainring position.
    Kevin
