Singlespeed Turner!!!- Mtbr.com
Results 1 to 8 of 8
    Fun to tool around the driveway for now, can't wait to get it out on the trail:
    Right now it's setup with and standard cassette and XTR rear der. that's fixed on the 20t cog.
    James
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Quote Originally Posted by jjcarr
    Looks light and zippy! Will you be ditching the Rder and cogset for a tensioner and SS-freewheel or keeping your options open?
    I forget what model & year is that? BTW How much does it weigh?
    Faster is better, even when it's not.
    Quote Originally Posted by Bikezilla
    Keeping options open for now, need to find out what gearing works best. It's a 1998 Stinger. No sure what the weight is, probably about 26lbs right now, several of the parts are pretty heavy. Should be easy to get it down to 23-24lbs, but I'm not in any rush.
    .......you'll most definitely need some sort of chain tensioner that will allow for some growth (spring). The chain growth may be minimal on that design, but it is enough that it will break any chain if you start with the correct length......
    Quote Originally Posted by jncarpenter
    That's why the deraileur is on there.
    Reputation: Soupboy's Avatar
    Check out the Rohloff...
    ...front ring guide - bolts on to ST. Once you settle on a gear of your liking you can shed the weight of a full cassette and just run a DX or King Kog with spacers.
    You will throw chains in that set up unitl you lose some links and run a front ring guide. If you're ok with using the derailleur in lieu of a Melvin or Rohloff chain tensioner you should be golden.
    Cool ride.
    Sean
    Professional Amateur
    Flyin Canine
    Reputation: shanedawg's Avatar
    I agree with soupboy. If you take it out on a bumpy trail your chain will most likely fall off the front ring. I tried the same setup on my old hardtail and had to put the ft derailluer back on to contain the chain when it tried to bounce off.
    Quote Originally Posted by shanedawg
    Hm....I'll have to look into my options. For now I'll just put the front der. back on and fix it, then see how I like the ride. Thanks for the tip.
  1. Cuervo / DHR / V10 review (long)
    By Scott@GO-RIDE.com in forum Downhill - Freeride
    Last Post: 06-23-2004, 10:03 AM
  2. What Is The Best? V10 Or El Cuervo??
    By gabri3ride in forum Ventana
    Last Post: 05-05-2004, 07:24 PM
  3. Maverick Fork Approved for Turner 5-spot
    By Maverick American in forum Maverick
    Last Post: 04-22-2004, 09:12 AM
  4. Turner Demo Bikes stolen - Temecula
    By gregg in forum California - Socal
    Last Post: 02-05-2004, 12:20 PM
