Results 1 to 10 of 10
    127 is offline
    Rock Shox Monarch RT3
    Hello
    Could someone tell me, whick Rock Shox Monarch RT3 rear shock suits best
    to 5 spot -09 ? There are low, mediun and high factory tunes.
    Quote Originally Posted by 127 View Post
    Hello
    Just order one custom tuned from Push, they are on sale right now. And when you talk to them ask them what Monarch they recommend.
    Push Industries - PUSH Tuned MTB Shocks
    Reputation: hafnz's Avatar
    Quote Originally Posted by kmac999 View Post
    I'm quite interested too on what would be the correct, off the shelf, tune for the 5 Spot, as Push doesn't send overseas (if the info in the OP's profile is correct he's in Europe as I am).
    I've read on another thread that it would be the low but that Push makes an even lower, any one has any experience with a low, off the shelf, tune?
    (some experience with the Plus RC3 is welcome too )
    Quote Originally Posted by hafnz View Post
    Is TF-Tuned not doing monarchs in Europe for Push? If I was you I'd still email Push for their recommendation, Darren is very helpful and I'm sure he would answer your question as would the guys from Turner if you emailed them.
    TF Tuned, from their website (and I believe someone else here asked them directly) doesn't do Monarchs (which is a shame).
    I already thought of asking, haven't come around to actually doing it as for now it's just a curiosity (don't have a 5 Spot yet - yet the OP probably has).
    I can't help then, but the OP should just shoot Turner an email about it.
    127 is offline
    OK. I will ask from Turner then. Yes, I have -09 Spot and I am from Finland (Europe).
    I am not totally happy with Fox RP23 shock, which came with the frame. Perhaps I should try first, that modification to shock, which reduce air volume. I find it now little too easy use all travel.( its not enough progressive).
    I have already RT3 shock (normal air can modification) in my other bike Commencal Meta 5 and I prefer it over origal Fox RP23.
    Reputation: qbert2000's Avatar
    sounds like the dgc mod is worth trying
    Reputation: KRob's Avatar
    Quote Originally Posted by qbert2000 View Post
    Ditto. I would start there. It's cheap and easy to try. I've finally got my RP23 working pretty well with the DGC mod. It ramps up nicely at the end of the stroke and resists bottoming on all but the bigger drops yet I can still run lower pressure to get the desired sag so it stays plush on the initial part of the stroke. Mid stroke support and control also seem pretty good. The rear wheel seems to stay glued to the ground on fast rough sections better now too.
    Having said all that, I'm interested in the Pushed Monarch RT3 especially at that price. Better is always good, right?
    Isaiah 58:14
    www.stuckinthespokes.com
    This will help, work out what stroke shock you have and the amount of travel. this chart will show you which tune to go for
    http://www.qbp.com/diagrams/TechInfo/vivid.pdf
  1. rock shox monarch rc3 plus vs monarch rt3
    By allenfstar in forum All Mountain
    Last Post: 08-27-2011, 05:07 PM
  2. Rock Shox Monarch Plus RC3
    By bigmike9699 in forum Shocks and Suspension
    Last Post: 03-08-2011, 09:59 PM
  3. Rock Shox Monarch RT3
    By superbrew in forum Shocks and Suspension
    Last Post: 10-17-2010, 10:25 AM
  4. Rock shox monarch help
    By mudmav in forum Shocks and Suspension
    Last Post: 05-12-2010, 07:08 AM
  5. Rock Shox Monarch 4.2
    By G-VegasMTBiker in forum Shocks and Suspension
    Last Post: 03-11-2008, 05:31 AM
