Q about greasing the pivots- Mtbr.com
Results 1 to 3 of 3
    I attempted to grease the pivots on my 08 Spot tonight, for the first time. How can you tell if any grease is getting into the pivot? None is coming out the sides/gaskets so I really can't tell if I'm getting any grease into the pivot.
    Also, how do you access the zerk at the shock pivot, right behind the shock?
    TIA
    Reputation: flipnidaho's Avatar
    Remove the shock for access... I pump grease until there is some resistance...
    Reputation: rku615's Avatar
    I use this
