Results 1 to 6 of 6
    Reputation: RiceKilla's Avatar
    Please carify for me, about to purchase
    Looking at the Push site, I am seeing the Pivot Kit for Turners at 32.95.
    Now I want to be sure it says for that price you get the bushings and the seal kit.
    So I get the red things(seals) plus the bushings, err journal bearings? Is this correct?
    I tried calling Push but no one answered, I guess everyone is on vacation. So I turn to you guys for the answer.
    PS - in case Push sees this, is there anyone in the office to take orders?
    2006 Turner 5 Spot
    2007 Trek 2100 ZR
    The red things are the bushings....the seals would be the rubber rings that help keep grease in, dirt out.
    Hmm, I just ordered.
    Spoke to the rep on the phone. Asked if this included the "journal bearings", they said yes.
    Welp, either way I don't think anything needs replacing, but going to do it anyway, I figured why not.
    2006 Turner 5 Spot
    2007 Trek 2100 ZR
    Quote Originally Posted by RiceKilla
    That's because journal bearings = bushings = red things in picture
    Moosehead
    Reputation: moosehead's Avatar
    RK, the Push Bush Package gets you both the red journal bushings and the black seals (flat rubber o-rings). You will re-use your torx bolts and pivot shafts. Also a good idea to get a longer handled wrench on the torx bolts to prevent bolt and/or knuckle strippage.
    Also check out DGC's recent threads about the Enduro needle bearing kit for the shock mounts - replaces the DU/reducers.
    Thanks for the clarification.
    OK then, I was confusing journal bearings with the pivot shafts.
    And moosehead, I will definitely be doing that needle bearing upgrade. The bike is receiving a big time refresher in January.
    2006 Turner 5 Spot
    2007 Trek 2100 ZR
