Results 1 to 13 of 13
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Pike 454 Oil Change?
    Can someone direct me to a decent thread with steps for changing the oil in a 454-UT?
    I did a quick search but didn't quite find anything.
    Tnx.
    Faster is better, even when it's not.
    Reputation: CrashTheDOG's Avatar
    This is the best one I've found.
    Lay off the Levers
    Reputation: Chasintrane's Avatar
    Lay off the Levers
    Quote Originally Posted by Chasintrane
    Big help! DGC... couldn't have a better author.
    So this thing runs on just 16cc of oil in each leg???
    Seriously? The damper sucks it up? or does the damper have it's own internal oil?
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Quote Originally Posted by Bikezilla
    Use the RS tech manual. That 16cc you're referring to is just in the lowers, damper oil is separate.
    http://www.sram.com/en/service/
    Larry
    www.mtnhighcyclery.com
    "It is inhumane, in my opinion, to force people who have a genuine medical need for coffee to wait in line behind people who apparently view it as some kind of recreational activity". - Dave Barry
    Lay off the Levers
    Many thanks Larry!
    Reputation: kendogg's Avatar
    You might want to replace the o-rings while you're at it. None of the local lbs's had the service kit in stock when my REBA was getting stuck down last year. A quick trip to my local Ace hardware, and I was set. Just take out all the o-rings and take them to the store to match them up. BTW, even though the fork was made overseas, none of the seals were metric. The fork's been holding air ever since, and it only cost about $3 to change all of the seals, which beat the shiz out of the $25 bucks for the kit from SRAM!
    Arf, he said.
    Reputation: mtbdawgJeff's Avatar
    This article is about Reba service, but mostly applies to the Pike as well. Lots o pics.
    http://www.bikeradar.com/gear/articl...on-forks-23142
    ROBOTIC RESERVE
    Reputation: Captain Snakebite's Avatar
    This was very helpful for me....
    http://www.youtube.com/watch?v=Yu_moia-oVI
    Captain's Rides
    2008 Turner 5.Spot Raw - Pushed RP23 / Pike 454 U-Turn
    2008 Turner Highline GDO - CCDB / Fox 40
    err, 27.5+
    Reputation: AL29er's Avatar
    Push it, you know you wanna
    Be sure to get the factory kit, it really transforms the fork (in a good way )
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Te mortuo heres tibi sim?
    Nothing that isn't covered in the linked stuff here, but if you need a hand, I'm free tomorrow and have done plenty of Pike oil changes.
    Suspect you'll be fine though.
    Lay off the Levers
    Many thanks bro!
    I think I'll be cool.
    Where/when you riding t'morrow?
