    jrm
    jrm is offline
    Reputation: jrm's Avatar
    offset lower shock pin question
    If i run the lower pin with the hole in the 3 or 9 o'clock position is that the same as OE? Thanks
    Jun 2017
    I assume that means you have vertical shock mounting, and 3 or 9 o'clock would mean that the distance between the pivot point and the frame mount is nearly the same?
    This will change your lever ratio, so it'll change the amount of travel the frame has, as well as the stiffness. Not sure how much though.
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Those bushings don't really offset very much. You're not going to change your travel at all, and not the leverage rate by any appreciable amount by doing that in the lower hole of a turner.
    It will mess with things a little more in the upper link because the bushing rotates along with the link. That might change things a bit more noticeably.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
    They will raise/lower your bottom bracket a bit though. Converted my Sultan to 27.5+ and the offset bushing helped to raise the bb for a bit more clearance.
  1. Replies: 0
    Last Post: 03-12-2017, 09:31 AM
  2. Replies: 11
    Last Post: 03-06-2013, 07:38 PM
  3. offset Large Marge to "non-offset" turing?
    By toezter in forum Wheels and Tires
    Last Post: 02-06-2013, 07:15 PM
  4. Replies: 3
    Last Post: 09-06-2012, 05:46 PM
  5. Difference between offset and zero offset seatpost
    By D3NN15M in forum Beginner's Corner
    Last Post: 06-28-2011, 07:39 PM
