Results 1 to 2 of 2
    Dec 2008
    O2 front del size ?
    Does anybody know what size front Del. that I need on my 2002 O2 build, I have a 28.6 XTR but it is to small.
    Thanks for any info
    Quote Originally Posted by downbush
    Thanks for any info
    Turner's web site has an excellent tech/FAQ and model info sections.Any questions usally can be answered there.But anyhow all Turner's that can take a front der. will take a 34.9mm.For the 02 depending on frame size what works best?A high clamp bottom swing or low clamp upper swing.The 02 I had was a 16.5" and I was able to use a low clamp upper swing with the clamp mounted between the upper and lower points on the lower shock mount.Best to double check with the web site.Hope that helps.
