Results 1 to 7 of 7
    Reputation: tholarsch's Avatar
    New question here. Minimum seatpost insert?
    Hi guys
    How much is the minimum seatpost insert required on a 2006 Flux and a 2006 5-spot?
    Both bikes are medium and i have a Thomson seatpost thats 350 mm for both bikes...
    But I was wondering if 9-10 cm insert is enough?
    Would it be smarter to run a 410 mm Thomson, that would give about 15 cm?
    Regards
    I think Thompson recommends 3 inches and if I'm not mistaken DT recommends 4 inches, so 10 cm should be fine.
    Thanks for the quick response :-)
    Where did you see the Turner recommendation?
    I read it on this board. If I recall DT said 3 in will work , but recommends 4 in. Now Jenna J might disagree with that, lol. You may want to do a search for on minimum seat post insertion or something to that degree. It should be on here.
    Ok - Thanks!
    Reputation: Dibbs_'s Avatar
    100mm or 4 inches
    it's on the FAQ's section of the Turner website
    Must have been slightly blind there for a moment ...
    Youre quite right, its right there in the FAQ :-)
    Thanks again.
