Marzocchi 2007- Mtbr.com
Results 1 to 31 of 31
Thread: Marzocchi 2007
    Reputation: rodel's Avatar
    Marzocchi 2007
    website updated with new goodies!
    so does this mean they are available now?
    Marzocchi 2007
    Outcast
    Reputation: Renegade's Avatar
    the website says the 66SL ATA weighs 6.8 pounds! What's with that? Does ATA weigh 1.2 pounds?
    Xtremely Moderate
    Reputation: e<i>o's Avatar
    Quote Originally Posted by Renegade
    My new Boxxer Ride is less than a 1/2 lb. heavier and its not that ghey virgin white..........
    "Korash your enemiez, zee zem driven bevore you, and ear ze lamentation of za vemen"
    Quote Originally Posted by e<i>o
    888SL ATA only comes in white
    Outcast
    So EIO, are you gonna lend me your 888?
    Yea, I can't handle the white lowers. They must have gotten the weight wrong, you know, a typo error.
    not so super...
    Reputation: SSINGA's Avatar
    what is all this smack talk about white lowers?
    Nothing to see here.
    Is That Right?
    I Thought it was to be like 5 something. What's with the 6.8?
    Xtremely Moderate
    Quote Originally Posted by SSINGA
    Never you mind Creamsicle.................
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    1.5lb heavier and don't forget the dinky stanchions on your boxxer either.
    Outcast
    Quote Originally Posted by CRAZY FRED
    Fred, it's got to be a typo error. This year's 66SL is 5 and a half pounds. There's no way it gained over a pound with just a small change to the doppio cartridge.
    Xtremely Moderate
    Quote Originally Posted by Jayem
    Yeah I'm sure they'll fold in half on the 1st pebble I hit ..............
    ........none of my old Zoke's ever did.
    Outcast
    I recieved a spam e-mail from marzocchi; it had this little diagram in it:
    trail fairy
    Hay why is this link taking soooooooooooooo long to upload
    argh I want 2 c 07 Marz now
    Gimme now
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    Team Sanchez
    Reputation: El Chingon's Avatar
    Where did you guys find the weights? Someone hook me up with the weight on the 66 RC2X.
    Outcast
    Quote Originally Posted by El Chingon
    Where did you guys find the weights? Someone hook me up with the weight on the RC2X.
    The weight of the sl model was given in it's description, but the other two model descriptions do not include the weights. another reason to doubt the alledged weight of the sl.
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    2007 - 66 RC2X
    180mm travel
    565mm AC
    2.91Kg (6.4lbs)
    more info: http://marzocchi.com/Template/listSP...K&Sito=usa-mtb
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
    Team Sanchez
    I"m diggin that Charcoal gray color. Looks like the 66 RC2X will be the fork for me for 07!
    Outcast
    thanks Scubapro. The weight table confirms my earlier suspicion. Sl weighs 2379 grams [probably without steer tube], which is 5.31 pounds. It's the RC2X that weighs 6.5 pounds [w/o steer tube].
    Correct. + 255g for reinforced alloy steertube = 5.8 pounds for 66SL ATA.
    trail fairy
    Hay guys
    <table align="center" border="0" cellpadding="2" cellspacing="2" width="100%"><tbody><tr valign="top"><td class="products-series-td-2007-66">66 RC2X</td> </tr> <tr class="products-specs-td-scuro" valign="top"> <td align="right"> <table id="stampa" border="0" cellpadding="2" cellspacing="1" width="100%"> <tbody><tr> <td>66 RC2 ETA </td> <td align="right">66 SL 1 ATA </td> </tr> </tbody></table> </td> </tr> <tr valign="top"> <td>The 66 is the long travel single crown fork that many try to imitate but none can duplicate. This fork delivers with function and technology. This year we’ve integrated the all new ATA system into the fork as well as ETA in case you need to climb instead of shuttle your closest trail. Progressive riders demand a fork that works on the big drops with the freedom of a single crown. The 66 is the only choice.
    <table class="products-series-td-2007-66" border="0" cellpadding="4" cellspacing="1"> <tbody><tr> <td class="box-interno-td">- 180mm Travel
    - RC2 Adjustability
    - Coil Spring
    - Reinforced Alloy Steer Tube & Crown
    - 35mm Alloy Tapered Stanchions
    - 6” Post Mount (Max Disc 8”)
    - 20mm Axle</td></tr></tbody></table></td></tr></tbody></table>am I reading this right RC2x with ATA and ETA
    MAXXIS 4C!
    Leatt FAQs
    Outcast
    No, you are reading a poorly written webpage. The SL has ATA, the RC2 has ETA, and the RC2X has neither.
    aka...appBLING72
    Reputation: aappling72's Avatar
    My 06 66 RC2X weighed in at 6.3 with a 8.5 inch steer tube.
    Well, something might fold in half.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    My new 2007 ETX RC4 m-FRX has the new spring tension FSBv. They've also integrated an air-assisted DRG valve in the MT-05 chamber for extra preload in low damping situations. I'm really excited about this advance from last year's MT-04 chamber, which overloaded in repetitive impacts due to the oil fluctuation in the side chamber - thank gawd they've addressed this!!!! All in all, the ride will be so much improved - and it lost 0.5 grams!
    Well done, Marzocchi!!!!
    Do you think we could get clarification from Brian P on this issue?
    Mar 2005
    Quote Originally Posted by aappling72
    Haaaa Haaaa.
    I truely like their stuff
    but
    the website and the info given to the general public is pathetic!!
    trail fairy
    Renegade No, you are reading a poorly written webpage. The SL has ATA, the RC2 has ETA, and the RC2X has neither.
    Cheers I thought it was weird, um sounds like an 07 66 RC2X might be too in flexible for my RFX A2C increased more travel and seems non adjustable internally, could be an SL now or Lyrik, found out we are only getting the 2 step lyrik in NZ um want coil but seem to always end back up on air..
    Someone convince me the 07 66 SL with ATA will be the Shizz for me RFX
    Cheers team
    MAXXIS 4C!
    Leatt FAQs
    not so super...
    Quote Originally Posted by trailadvent
    Cheers team
    The SL is the Shizz for the RFX.
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    Its gotta be a typo since they are saying that the 888 SL ATA is only 6.5 lbs.
    Xtremely Moderate
    Only if it has black lowers though.............
    trail fairy
    Im soooo convinced
    They come in White too for 07, white the old Pink or new green or whatever
    Im soo last year
    Gime white, this will probably sway me from the Lyrik then I may get an 06 RC2X if I can find one as theyre white 2 and its a coil
    MAXXIS 4C!
    Leatt FAQs
