Looking for cane creek db coil- Mtbr.com
Results 1 to 6 of 6
    Looking for a used ccdb 7.5 x 2 coil for my 5 Spot. Having no luck in the Vancouver bc area thought maybe some good Turner people may help me out. always wanted to try a coil on my Spot just know it would be so good.
    Reputation: Buzz's Avatar
    I had one on my 2005 Spot and then transferred it to my 2012 Spot. Sold it about a year ago when I found a DBAir CS. Vancouver area also! Make sure it will fit in your frame before you buy it. There are clearance issues depending on the year and size of your Spot.
    Feb 2006
    PM Sent.
    I have one that I had listed locally in South Carolina that I could ship if you are interested. Also, Buzz is right about fitment. I had it on an XL 2011 Spot. It just barely fit without any modification. I have read that some people have had to file a little material off the gusset on their frame or the collar on the shock.
    Mine barely fit on my 2012 large spot. When I switched to the ccdba cs, I had to file the gusset where the air can was making contact with the frame.
    Got my ccdb coil on my 2013 5 Spot. Spring just clears gusset.Thank you bonesteel. All I can say is wow. Just so much better than that Fox float. Worth every bit of that weight penalty. Just a little mixed up now with a coil on the 5 spot and ccdb air on my DHR.
    Feb 2006
    Awesome, I'm glad it worked out for you! Happy Trails!
  1. Cane Creek DB Coil LSC fail
    By nhodge in forum Shocks and Suspension
    Last Post: 01-03-2016, 04:21 PM
  2. Demo 8 Cane Creek DB Coil Mounting
    By hespeler in forum Specialized
    Last Post: 07-07-2015, 08:19 AM
  3. Cane creek air to coil
    By tom34 in forum Knolly
    Last Post: 04-09-2013, 03:32 PM
  4. Review: cane creek db air vs coil
    Last Post: 04-08-2013, 08:20 AM
  5. Cane creek Air Vs. Coil
    By kidmojo in forum Ibis
    Last Post: 10-14-2012, 04:08 AM
