Limiting coil shock stroke ?- Mtbr.com
Results 1 to 3 of 3
    I need to reduce the stroke 1/4" on a coil shock. Could a notched plastic spacer be placed under the bottom out bumper ? Thanks.
    Outcast
    Reputation: Renegade's Avatar
    yes; been there, done that, it works. Plastic or hard rubber works fine.
    trail fairy
    Option 1 not knowing what bike or shock i2i etc it is?
    1: You could add another bumper stop, so you run two stops! a Sam Hill trick..
    2: Or add more compression depending on your shock, HSC, or C and bike I'm guessing an RFX being a coil shock but could be anything in homerville though, Nitrous to DHR lol !
    3: Change rockers [if RFX] lower leverage rate sits higher in travel pedals better, all depends on what bike ya have and how ya want it to ride, just shortening the stroke is hard to go by
    Rest is guess work without knowing the bike!
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
