Life span of DHR Frames?- Mtbr.com
Results 1 to 6 of 6
    (was) Big in Japan
    Reputation: TheSingleGuy's Avatar
    I have a 2001 DHR. I love this bike! I believe it is still a competitive DH bike, and I want to keep on loving it (not in the Biblical sense!). But it needs new needle bearings in the linkages, and the Fox shock just died. I'd love to get it fixed, but am worried about spending the cash over winter, and then having the frame/swingarm crack next season. Seems like a strong bike to me, will it hold up? It already has three hard seasons under its belt.
    Here's a pic!
    Any recommendo for a new shock?
    Ride.
    Flyin Canine
    Reputation: shanedawg's Avatar
    Not sure about the lifespan question but if the shock just has blown seals or something why not get it serviced at fox or even send it to Push? It's a lot cheaper than buying a new shock like a romic and it doesn't look like you have clearance for many of the shocks on the market like the dhx or 5th anyway.
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Interesting read
    http://www.ridemonkey.com/forums/sho...ight=DHR+crack
    In summary (my experience, not just what's in that thread)
    01,02 frames : Ovalizing headtubes, cracked shock mounts (more so with the bolt on mount version
    03: Broken swing link, goes pretty quickly, mine happened within the forst 10 rides, broken main pivot housing-high stress area too close to a weld on thin aluminum
    04: Haven't heard of anything constistent yet
    I still see lots of frames like yours around being ridden pretty hard.
    (was) Big in Japan
    thanks dude,
    I will check that out for sure. There are still heaps of them here in Japan too. They seem to last here, but most Japanese riders are a lot lighter than me.
    I also heard that they can crack near the main pivot if you continue to ride them when the main pivot gets sloppy. Makes sense, mine was really loose and moving side to side A LOT.
    Ride.
    Now with flavor!!
    Quote Originally Posted by TheSingleGuy
    Yeah make sure you keep that thing tight. Don't EVER ride it loose or you'll be putting a lot of stress on the swing link as well as causing impacts at the main pivot. I know the older ones needed pretty frequent checks.
    (was) Big in Japan
    Loctite
    Quote Originally Posted by kidwoo
    Loctite did me proud, It was never loose except for the bearing play. But I changed the main pivot bearings a while ago, as well as the pivot shaft, and it was great. Then the needle bearings in the linkages died! Oh well, it was WAY OVERDUE for TLC. Thanks for the link to RideMonkey, that was an interesting read, and reassuring enough to tell me to stick with the DHR.
    Damn fine bike. Dunno if I could go back to a bike with a high BB now...
    Ride.
  1. Opinionaire: Do frames "Wear Out"?
    By Bikezilla in forum General Discussion
    Last Post: 02-12-2005, 10:45 PM
  2. what is the life span of a fork?
    By Reek in forum Shocks and Suspension
    Last Post: 10-10-2004, 03:27 PM
  3. Cuervo / DHR / V10 review (long)
    By [email protected] in forum Downhill - Freeride
    Last Post: 06-23-2004, 10:03 AM
  4. What Is The Best? V10 Or El Cuervo??
    By gabri3ride in forum Ventana
    Last Post: 05-05-2004, 07:24 PM
  5. Life span of FSA DH pig pro?
    By wayneosdias in forum Downhill - Freeride
    Last Post: 03-28-2004, 04:37 PM
