Results 1 to 9 of 9
    Kermit, the frog - 5 Spot build advice requested
    After having lingered on this forum for the better part of two years the TNT-horrors made me finally jump to secure me a HL spot! Having analyzed the various builds represented on this board, I´ve come up with below specs. As nothing´s yet set feel free to comment away and help me get Kermit the build it deserves... thanks
    * Fork: Pike 454 Air U-Turn
    * Rear Shock: Fox DHX Air
    * Brakes: 06 Hope Mono M4 w/braided lines, floating rotors, post-mount
    * Cranks: 06 XTR
    * Front Derailleur: XTR
    * Rear Derailleur: XTR 952 short cage
    * Shifters: XTR 952 9spd
    * Pedals: Shimano M959/M545 depending on trail
    * Stem: Thomson 31.8 100 x 5
    * Handlebar: Titec Pluto 1.5 inch rise, carbon fiber
    * Seatpost: Tune Starkes Stueck
    * Seatclamp: Tune Wuerger
    * Saddle: Flite Alpes
    * Cassette: XTR 11-34
    * Chain: Dura Ace
    * Headset: Tune Bobo
    * Grips: Ruffian Lock-On
    * Tires: Nevegal 2.35 Stick-E
    * Rims: Stan´s ZTR 355
    * Hubs: Chris King, 20 mm ISO front/ISO rear
    * Spokes: DT Competition, alloy nipples
    * Skewers: Maxle front/Salsa steel rear
    Less is more when more is not enough...
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Looks great but I'd do a King headset (why anything else??) and a Sram trigger shifter/rear der combo.
    My video techniques can be found in this thread.
    Reputation: Prof's Avatar
    Lovely, all I would suggest is a rollamajig and a long cage rear mech and 2.10 tyre at the rear.
    Oh and ditto on the CK headset.
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    the 31.8 s/post may be a issue as well. turner uses a 27.2 on everything as far as i know. i agree with prof. the short cage xtr will pretty much destroy the cogs, rings, crank, chain and hanger on the first missed shift not to mention feel a bit draggy on some gear combos and prematurly kill a chain that needs no help diein a quick death. a 2.1 might be a better way to go unless its gona fall off everything in its path or yer a big guy. have fun collecting yer bits!
    No, I'm NOT back!
    Living the Dream
    Reputation: Alpenglow's Avatar
    Beautiful Frame
    Echo what Tscheezy said about the Sram Trigger/derailer combo--I use the X9s. I have not ghost or mis-shifted in 1.5 years of using them. You also don't get chain slap with Sram.
    "And I shout that your all fakes and you should have seen the look on your face"
    Reputation: G-AIR's Avatar
    read the fine print
    Quote Originally Posted by cactuscorn
    the 31.8 is referring to the Thomson stem not the seatpost. It is for oversized bars. It seem like most people are heading this direction. He is not getting a thomson post.
    doh! i done did it again. see below.
    No, I'm NOT back!
    Zip
    Zip is offline
    Joe Dirt Status
    Reputation: Zip's Avatar
    Sweet looking frame!! I love it!!
    Ditto on the Sram components. I have a XO rear mech and a X9 trigger, both 2 years old and I've had nothing but smooth, hassle free performance. I would also get a quick release seatpost clamp (Salsa,Hope). Other than that you look good.
    I think it's all a royal mess and you should just give up and send me that frame and start from scratch with something else....hehe. No, seriously, the Pike will be awesome but go with a King headset...in a different frame! I just want that green for a Spot of mine.
    Bryan
