i need to fix up my air sleeve on my spot...- Mtbr.com
Results 1 to 13 of 13
    how heavy are you ??
    Reputation: Scottay5150's Avatar
    can i leave half of it mounted in the frame? i do not have a vice to hold it in. Would I ruin the bushings? What do you think?
    Scott
    P.S. Does the fork still have reliability issues still?
    TLL
    TLL is offline
    Reputation: TLL's Avatar
    What is your question, exactly? What are you "fixing up?"
    Hadley rear hub service here and here.
    trail fairy
    What TLL said, shock ? fork? what fork has relibility issues, where good but we don;t know everyones setup not yet
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    sorry sorry....
    yeah i am servicing my air sleeve on the RP23... I supposedly need a table vice to keep the shock put... what do you think now?
    Scott
    trail fairy
    That would be best, you can use a bit of wire or zip tie to hold ya rockers up!
    I use my Park Tool stand clamp for vice duties, sorta became my trick on the road at the races
    chur.
    MAXXIS 4C!
    Leatt FAQs
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Quote Originally Posted by Scottay5150
    Scott
    You mean to unscrew the air sleeve? You could, it would be easier to put a screwdriver through the eyelet.
    _MK
    so in other words...
    it is an easy repair?
    Scott
    Time flies...
    Reputation: xjbebop's Avatar
    search...
    http://forums.mtbr.com/showthread.php?t=427530
    ...lots of other threads out there...
    ...every day sends future to past...
    trail fairy
    Scott
    Fox has some good info on there repair site and videos etc also
    MAXXIS 4C!
    Leatt FAQs
    watched the video
    didn't like it...
    Scott
    trail fairy
    didn't like it...
    Scott
    Oh can;t be that hard, where's tscheezy when ya want him, probably out playing on his Spot again, or is it bed time in Alaska
    MAXXIS 4C!
    Leatt FAQs
    Ak
    Quote Originally Posted by trailadvent
    its summertime.... always daylight... riding at midnight.. no lights
    Scott
    TLL
    TLL is offline
    Just do what MK tells you.
