I have a black one!- Mtbr.com
Results 1 to 12 of 12
    mad aussie
    Reputation: Flying Wombat's Avatar
    I have a black one!
    Having posted a few times, I thought I would post a picture of my black 'spot.
    Total weight with small frame is 30lb. It does have Turner decals, but I have the silver outline on black so they are hard to make out in the photo.
    After a year of riding in Phoenix the pedals and cranks are looking a little the worse for wear, but still holding up fine.
    [IMG]
    I love the black/polished rear combo. That thing looks sweet.
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Quote Originally Posted by Flying Wombat
    Nice, very nice!
    How are you getting along with those XMaxXL wheels? My rear wheel has been problematic.
    Faster is better, even when it's not.
    mad aussie
    Quote Originally Posted by Bikezilla
    Nice, very nice!
    After a year, not a single problem to this point, I have had to tighten the rear hub a couple of times, but never trued them once. At a little under 140lb I tend not to be really hard on equipment, although I do like to jump, but nothing over 5-6 feet.
    Lay off the Levers
    Jah! yeah we're on opposite sides of the spectrum. I'm 220lbs, and never came close to five footers, but do ride on the hard side. ENJOY!
    Reputation: jennasdad's Avatar
    Bikezilla, what problem(s) have you had with the rear wheel?
    Lay off the Levers
    Quote Originally Posted by jennasdad
    It used to creak a lot until I started using a lot of skewer tension. I also get a steady rain of spoke-ping...sort of a tinkle-tinkle-ping-ping noise. I've had the wheel retensioned twice, once at Mavic. My LBS is working with me on this which is a good thing. I've also found the spokes easy to damage, and expensive to replace.
    Overall I like how the wheelset performs, though I'd like faster engagement on the rear hub.To be fair I haven't come across anyone else experiencing the same problems.
    I haven't used those wheels, but my Rolf wheels used to ping like crazy. I used to play around with spoke tensions and that seemd to help. So did tightening the skewers, but the pinging always returned. It turns out that the pinging was caused by bad bearings .....the play caused the spokes to ping. I'm willing to bet that you have a similar issue with your hubs / bearings
    Lay off the Levers
    Quote Originally Posted by WarrGuru
    Hmmm the strange things that cause bike sounds. The LBS adjusted the bearings a couple of times, but I'll fiddle with them the next time I have it up on the stand. It could easily be like CKs and need periodoic adjustment. Thanks for the tip!
    Reputation: Larsey's Avatar
    Nice Ride Wombat
    Just curious, how tall are you? What length stem are you running on the small? Thanks.
    Reputation: the Inbred's Avatar
    oh. damn! and black/silver stickers to boot. hot.
    just need a black rear end.
    black RFX and 5 Spot. ye-ow. good day to check the Turner board.
    mad aussie
    Quote Originally Posted by Larsey
    I am 5'6" and running a 100mm stem. I have tried different lengths, but the 100 seems to give a good balance between climbing vs descending
  1. Black Elite 100/120mm vs Fox Vanilla RL
    By Akali in forum Shocks and Suspension
    Last Post: 06-21-2004, 06:03 PM
  2. Fox pro pedal WOW!
    By Bird in forum Shocks and Suspension
    Last Post: 04-28-2004, 12:17 PM
  3. Whats the dif between an Black Comp & Black Elite?
    By bdee in forum Shocks and Suspension
    Last Post: 04-06-2004, 09:44 PM
  4. Replies: 4
    Last Post: 02-02-2004, 02:01 PM
