Results 1 to 19 of 19
    Reputation: skunkty14's Avatar
    Jan 2005
    Homers: tips on truing rotors?
    Bent the front rotor on my RFX from crashing last week so it rubs in the caliper (J7s) a bit. I've done the typical adjustable wrench truing, but still have some high spots in both directions, so I'm looking for alternatives. Anyone had luck clamping a rotor between 2 pieces of 1 by pine or oak to flatten the rotor, or would the wood simply be too soft?
    Quote Originally Posted by turnerbikes
    in fact for trail type bikes I am tired of QR roady shite in general. Lets move on.
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    the problem with yer wood block solution is ya need to overbend stainless to make it hold shape so this wont work. if yer carefully home truein and it still wont go straight, i see 2 options: go to a shop that has the proper tools like trueing forks and a dial indicator, or buy a new rotor. hope that helps.
    No, I'm NOT back!
    Reputation: jaghouse's Avatar
    Morningstar tools
    Stand back
    Reputation: dbabuser's Avatar
    Performance also sells rotor truing tools under it's Torx brand. I've got some and they are well built.
    Golden Bike Park
    Golden Connector Trails need your support!
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    What Jag said: Morning Star Drumstix
    You can work a high spot by holding the adj ends at the same time. I just got a set from Chad at RedBarn. Can't wait to use em.
    Faster is better, even when it's not.
    Dishwasher Safe
    Reputation: deadbolt's Avatar
    Mar 2006
    Here's my set:
    RaD
    RaD is offline
    Trampelpfadbenutzer
    Reputation: RaD's Avatar
    Quote Originally Posted by deadbolt
    Here's my set:
    Looks like we use the same tools!
    Reputation: airwreck's Avatar
    Morningstar!
    the guy who makes them is super cool, and they are a bargain considering what you get for your money. Great instructions too. And don't be surprised if he gives you a call after the purchase to ask how they are working for you!
    p.s. I clamp a small metal ruler to my stays as a guide.
    Lay off the Levers
    Dammit Deadbolt! You've got adjustable truing tools? That's hawt! Thanks for the ruller tip Airwreck. I'll pick one up today.
    Dishwasher Safe
    Mar 2006
    Quote Originally Posted by Bikezilla
    Don't hate me 'cuz I'm beautiful.
    Jan 2005
    Thanks for all the responses. I think I'll have to grab a set of those Morningstar tools, those look like the ducks nuts.
    CC, I came to the same realization about over bending the stainless while riding earlier. Too bad I did think of it earlier before posting.
    Mt Wilson Motoboy
    Reputation: tedroy's Avatar
    Mar 2005
    Just go and...
    ... get a new one! You'll never get it back to where it should be! I bet those tools cost more than a rotor. Are you in some godforsaken place that you can't get a rotor?
    "My people are the people of the dessert!"
    said T.E. Lawrence picking up his fork...
    Reputation: Buzz's Avatar
    Depending on the truing stand you have (if you have one) you can use it to true your rotors too. Along the same lines as the ruler on the stays trick...
    I mount a dial indicator with a magnetic base to the side of my truing stand. Saves a lot of trial and error, eyeballing and guessing. Accurate to .001".
    ...ahhh, just noticed the one in the Morningstar pic. nice.
    Lay off the Levers
    Quote Originally Posted by tedroy
    Because bling ain't cheap:
    Also I can and have dinged my rotors several times in a season. Even XT rotors are ~$30 bucks each... I can't toss em like tubes.
    Rolling
    Reputation: lidarman's Avatar
    Quote Originally Posted by jaghouse
    Morningstar tools
    That shop mech sure has nice hands and nails.
    man you guys are sharp! trueing forks and a dail indicator? someone shoulda thought of that in the very 1st response.
    No, I'm NOT back!
    Quote Originally Posted by cactuscorn
    Didn't read it all. The sentence structure was making me crossed-eyed. My apologies. continue with yer truin.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    Here's what I use - very effective!
