Fox DHX for 5 Spot?- Mtbr.com
Results 1 to 8 of 8
    Reputation: Deano's Avatar
    Fox DHX for 5 Spot?
    I've been reading about this new shock and it sounds pretty darn good, I was wondering whether to get one as a back-up/service replacement shock for the Romic. I know it's a bit of a downhill/freeride shock, but the weight is OK and if the performance is as good as they reckon then...
    Info here:
    http://www.singletrackworld.com/article.php?sid=1381
    I have the press release if anyone wants it (I don't know if it's available on the Fox site).
    What other options would folk suggest as a standby for the Romic? Air is a possibility if the performance is good enough.
    ...not sure about a "back-up" for the Romic....definitely as a REPLACEMENT tho fo sho!! I too have been awaiting this shocks release (according to my last call in to Fox...maybe September 04). It is available in 7.5" x 2" spec......so, I am waiting, cash-in-hand
    Press Release .pdf HERE
    DGC
    DGC is offline
    Reputation: DGC's Avatar
    Get it if you can
    Quote Originally Posted by jncarpenter
    I have had a little test time on a DHX prototype back in March on a 5 Spot. It is a real nice shock. I would say it would replace your Romic, and then have the Romic be a second shock. The performance was extremely good. And I would guess the proto I rode is going to be basically production for the most part, since the performance was so good I could'nt see it changing. Get one if you can. Also, the shaft was aluminum vs. steel of old and dropped the weight significantly on the proto I rode.
    Ti spring...
    It's pretty easy to get ti springs for Fox shocks too isn't it? Damn this upgraditus!
    Thanks for your comments guys and great to hear from someone who's ridden one. Cheers.
    'The Fear' is your friend...
    Hey DGC
    Quote Originally Posted by DGC
    Do you happen to know how the weight of the DHX compares with the Romic? I'm itchin' to get one.
    Thanks!!
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Quote Originally Posted by Deano
    Hmmmm,
    I'd get a 2nd job but it would cut into my ride time
    Faster is better, even when it's not.
    Reputation: MARider's Avatar
    The press release states
    Quote Originally Posted by Blue Shorts
    Thanks!!
    400 grams without a spring on the larger 8.75 x 2.75 size.
    talk about upgraditus...I can easily see myself
    riding my 5 Spot this fall with a new DHX in the rear and a Manitou Nixon on the front. Yikes!
  1. 5 spot with fox AVA pro pedal
    By fastcash in forum Turner
    Last Post: 05-28-2004, 06:19 PM
  2. Fox DHX availability??
    By string in forum Shocks and Suspension
    Last Post: 05-15-2004, 05:29 PM
  3. Noticed Fox fork angle issue.
    By TNC in forum Shocks and Suspension
    Last Post: 05-14-2004, 05:45 PM
  4. Fox DHX @ Sea Otter????
    By SSINGA in forum Shocks and Suspension
    Last Post: 04-22-2004, 07:49 AM
  5. Fox F80RLT vs. my tired old Manitou
    By dgangi in forum Shocks and Suspension
    Last Post: 03-20-2004, 11:33 PM
