extra parts in my rear KING hub- Mtbr.com
Results 1 to 11 of 11
    over researcher
    Reputation: royta's Avatar
    I pulled the driveshell out of my rear King hub yesterday to clean and relube the ringdrive. I was amazed at what I found. There was a 3mm diameter rubber thingie up against the inside bearing in the driveshell. The end of the allen wrench to show where the rubber thingie was located.
    What's this all about? I removed the rubber thingie for less rotating weight. I hope to getting around to posting results later.
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    thats the fletcher valve seal. jam it back inside the bearing immediately!
    No, I'm NOT back!
    Reputation: Clyde S Dale's Avatar
    Jan 2005
    That looks like one of the little o-rings that one can slip on a cable to keep it from slapping against top-tubes/down-tubes/seatstays, etc. Just like the one pictured to the left.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Quote Originally Posted by Clyde S Dale
    agreed.
    I've take apart King hubs a number of times and don't recall ever seeing a tiny o-ring like that.
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    it's Fo's c0ck ring.
    Only boring people get bored.
    over researcher
    It's the same color and shape, but it certainly isn't the same size. It's roughly half the diameter of the o-rings I have on my shifter cables, and have seen on numerous other bike setups.
    I have no idea where in the manufacturing process an o-ring like that could have got into the mix. Strange.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Quote Originally Posted by royta
    How do you keep that bearing so clean? (the one where you allen is pointing). Do you spray some kind of solvent in there?
    _MK
    TLL
    TLL is offline
    Reputation: TLL's Avatar
    Mmmmmmmm, DONUT.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    Why not give Cameron a call at King Customer support.....?
    Don't quite know why you didn't do that first instead of waking me up and bothering me with your womanly prattle.....
    over researcher
    Quote Originally Posted by MK_
    _MK
    No solvent. I don't ride through the slop. Apparently it's very difficult for dry dirt to work it's way in there. The outer needle bearing was spotless too. Plus, I probably have less than 1000 miles on those hubs.
    over researcher
    Quote Originally Posted by jokermtb
    Hey, wake up! Quit sleeping your life away.
    I guess this thread was more of a "Look at the crazy stuff I found inside my King hub" thread. Not a "Whoa is me, my King hub is crap" thread.
