Results 1 to 5 of 5
    dhx air set ups for HL 5spot
    Hello !
    Thea mtbr search is F...up or mabye i am.
    But i could not find the old setup instructions with it
    trying the word DHX or DHX-air in Turner forum = 0 match!!!!
    I remember there was good topic and the man himsself DT , giving exellent setup tips.
    I forgotten these and would like to hear recommndations for 5spot 5.3 rockers -DHX air combo.
    i am 65kg currentrly running 33% sag 75 smal chamber and bottom allmost full in.
    on 1meter drop it bottoms sometimes (not good) and on long rooty descents it sortof freezes.
    all help is appreciated!
    Love and Freedom.
    Reputation: kendogg's Avatar
    Easy. Unbolt, discard, and replace with something else.
    what...?
    Reputation: jmtbkr's Avatar
    Without love in a dream it will never come true
    RPG
    RPG is offline
    Get the smaller air can for it if you really want to use it. i did just that and it did not blow through the travel. I then switched over to an rp23 and it felt even better.
    As far as set up, I had the bottom out resistance turned all the way in (progressive) and had about 150 in the boost valve. it needed to be firm as the mid range on the shock is not optimal for the 5 spot. Can't recall what I had in the main spring, but only had about 25% sag. Good luck and play around with it.
    thanks
    Thank you kind folks , just what iwas hoping for , but could not find.
    I am sure the rp23 would be better one , but i am short of money.
    Just reduced my weekly working days from 5 to 4
    to be able to ride more and spend more time with my girls.
    so upgrading is not an option right now.
    mabye if i could find push rockers somewhere? I coud be tempted to some serious money foolishnes and have the whole family eat porridge for a month.
    Love and Freedom.
