DHR Bearing Problem - HELP!- Mtbr.com
    Basically, my pivot shaft in the needle bearing (Journal bearing?) has somehow fubared itself. Its on an 06 DHR btw.
    I can no longer get a bolt through it. The previous owner got it part way through, but then it got stuck so it cant be tightened. Anyway, i whipped it apart and managed to get the bolt out... it took a vice and some brute force!
    So, im left with a pivot shaft thats internal diameter seems to be too thin? But Turner don't do replacements in the kit anymore. I've emailed Greg but he hasn't replied yet. And i feel i need to sort something out!
    So can i drill the shaft? As its just a few mm too thin. Or is there anywhere i can get one from?
    Many thanks!
    Toby
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Quote Originally Posted by Tobs
    You sure?
    What are you actually talking about? The main pivot or the linkage bearings?
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
    Linkage bearings.
    They have a pivot shaft.
    Ive sorted it now. Gave the old owner a ring, cheap Ti bolts that were slightly too big havent done it any good. So i've swapped some of them out for spair ones i had kicking around from my 00/01 DHR frame.
    Now with flavor!!
    Glad you got it working. I just use hardened black steel bolts from a hardware store. Stronger than the stainless stock ones.
