Clamp on F derailleur cable stop- Mtbr.com
    This is for you fellas with the older Spots looking to go up with the rockers.
    I wish I had the manufacturer's name or part number, but I saw a clamp on front derailleur cable stop in a small parts catalog a few years ago.
    If someone could locate one of these, it might help with those worried about the clearance at full compression on the older Spots. Or you could always use an automotive hose clamp
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Have you tried looking for it at Loose Screws?
    Faster is better, even when it's not.
    Just Grin and HUCK it...
    Reputation: SilverSpot's Avatar
    I spoke to DT about this a while back and he suggested:
    http://www.novacycles.com/catalog/pr...roducts_id=830
    Grind off the centered cable stop and rivet the new one on off center. Just be sure not to get too close to the seat tube rocker welds when you rivet the new one on.
    MCM# 2007.1
