Results 1 to 9 of 9
    Living the Dream
    Reputation: Alpenglow's Avatar
    Anybody using a 1X10 setup on Sultans?
    I have a 1x10 MRP mini g2 sl and I enjoy the gear range. However, I have to run it without the roller because of chainline issues. I am using the BB mount version. The question that I have is whether or not any one is using the MRP 1x seat tube version. I tried the e13 xcx seat tube version and it was not long enough. I want to use a seat tube version so that I can still use my heim guide with it. I think this will solve the chainline issues. Thanks for any help.
    "And I shout that your all fakes and you should have seen the look on your face"
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Im interested to know this as well. I need a guide for my Rohloff setup.
    This looks like it may have enough drop
    not so super...
    Reputation: SSINGA's Avatar
    Good to know about the e13. Was thinking it would be the ticket for my forthcoming 1x10 setup. What cranks are you using?
    Nothing to see here.
    used to be RipRoar
    Sep 1999
    I emailed MRP for the specs on the 1X ST K500. They said "The MTB seat clamp 1X from center of clamp has a adjustment range of 10mm-55mm."
    Looks like this will be perfect on my XXL with 34t...
    you guys are reading my mind! Let me know how this setup works for you please! I dont think I could push a 34 on my XXL Sultan ALL the time, especially on longer rides. Will this setup work for a smaller chain ring? I am running XX crank 2 x 10 with the 28 tooth small ring. I was thinking of going one smaller to the 26. I think i would use the whole rear cogstack then. Thoughts?
    not so super...
    Any feedback on the MRP?
    not so super...
    Quote Originally Posted by High Desert Norwegian View Post
    I'm going to start with the 28t small ring on my XTR cranks maybe going up to the 30t depending on how the 36t rear works out.
    4.0" fully suspended
    Nov 2006
    I ride 1X9 with mrp g2 sl on my sultan with 32t chainring. Works great (as should pricey) other than occasionally rotates (bb mount). Need to check bottom bracket tightness or come up with solution or not doesn't affect anything.
    not so super...
    Anyone try the MRP yet. I'm still waiting for my XTR rear dérailleur to get off back order.
  1. My 1x10 Setup on my Rune
    By mudpuppy in forum Banshee Bikes
    Last Post: 10-15-2011, 08:41 PM
  2. Commuter 1x10 Setup
    By Parnn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 04:10 PM
  3. Lightest 1x10 setup?
    By Josh-L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 12:44 AM
  4. Anyone running this on a 1X10/9 Setup?
    By joshuagore in forum Turner
    Last Post: 03-09-2011, 08:10 AM
  5. Can SS Chainring be used in 1x10 setup?
    By randyharris in forum Singlespeed
    Last Post: 01-27-2011, 06:36 AM
