Advice on buying a RP23 for a 5 Spot- Mtbr.com
Results 1 to 11 of 11
    I thinking of getting an RP23 to replace my DHX Air on my 5 Spot as I get through the mid stroke quiet quickly.
    I have on order some new Push Rockers and thought I would change the shock aswell, but I can't get a Pushed RP23 in the UK at the moment so will have to get a stock shock for now. There seems to be diffrent models of RP23 with light, medium or hard settings and large or standard air cans, what would be best?
    Team Blindspot
    Reputation: S-Works's Avatar
    Quote Originally Posted by Bubba Roy
    I would go with light. I ran the Pushed Rockers with a Pushed RP23 at the THC in Moab, and I never turned on the PP.
    Astigmatic Visionary
    Push recommends "light" for their rockers on a Spot.
    Flyin Canine
    Reputation: shanedawg's Avatar
    If you ordered direct from turner, I would think you would get one that is setup for the bike pretty well. Is this correct?
    Rp23
    Quote Originally Posted by Dusty Bottoms
    Dusty, how will you know if the RP23 is Light, Medium or Hard when you purchase one?
    What are the indicators? Thanks!
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    The propedal level indicator is on the shock's sticker. You can see 3 vertical bars (low, medium, high)
    I got a PUSH'd version with standard air can, seems fine with PUSH rockers here.
    PSI
    PSI is offline
    I want that one
    Reputation: PSI's Avatar
    Mar 2005
    replace my DHX Air
    if you wanna sell your dhx air im interested, please pm me
    Flyin Canine
    Quote Originally Posted by crisillo
    Dude, they are talking about the range of adjustments based on an initial factory setting. The lever has 3 different settings but it's the range within which the lever operates that is being dicussed here. Fox sets them up different for different styles of bikes.
    Quote Originally Posted by shanedawg
    I replied to this post
    Quote Originally Posted by znarf420
    So the 3 levels of factory propedal (the 3 RANGE bars), which is what matters when buying the shock, affect the level of damping that the 3 positions on the lever have, just as I said...
    Reputation: Jamie_MTB's Avatar
    Iíve just switched from a DHX-A to standard RP23 (its medium with a standard air can) with push rockers.
    Only had 58km ride time; but I love the propedal on\off and the push rockers totally sort the geo with the pike.
