8 Inch fork on XL Highline?- Mtbr.com
Results 1 to 14 of 14
    ROBOTIC RESERVE
    Reputation: Captain Snakebite's Avatar
    I'm looking for a new 8" fork, but as we all know the XL Highline has a monster 6" head tube. So with that being said. Is there any 8" fork out there I can run with out having any issues?
    Was looking at the Boxxer and Fox 40.
    Currently running a CC Double XC Flush headset, this only adds a few more mm to the total stack height.
    Captain's Rides
    2008 Turner 5.Spot Raw - Pushed RP23 / Pike 454 U-Turn
    2008 Turner Highline GDO - CCDB / Fox 40
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    I'm running the 888 on my XL HL and LOVE it!
    Faster is better, even when it's not.
    ROBOTIC RESERVE
    I'm currently running a 888 with flat Function Crowns. the only Problem is that its sooo heavy.
    Captain's Rides
    Lay off the Levers
    Heavy?
    Quote Originally Posted by Captain Snakebite
    Funny, I've been having trouble keeping mine on the ground!
    I re-read your OP. My bad. G'luck in your hunt! I'd be interested in reading your thoughts on the change.
    BTW, have you seen this?
    Is it my imagination or are they saying the stanchions are Ti???
    roots, rocks, rhythm
    Reputation: Dawgprimo's Avatar
    Nice air Zilla!!
    2010 888 mass is only 10g more than coil boxxer! Internals are a work of art too.
    http://www.bikemagic.com/news/article/mps/uan/7133
    ROBOTIC RESERVE
    Quote Originally Posted by burgundy snake
    Do you happen to know the weight of my current 2007 RCx2?
    Captain's Rides
    The internet has the answers you seek. Ride it like it was designed to be ridden. Weight is relative. Maximize your Power/Mass ratio 1st.
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    Can any of you guys comment on the handling differences of your highlines with a 200mm dual crown fork compared to a 180mm single crown. Are you using a flush lower cup with the dual crown? Do you have 7 rear ends?
    MoabMonster
    Oct 2007
    I used to run (7" version) a Fox 40 at 8" on my Highline, But have recently favored running the 40 at 7" in order to keep the BB low enuff for excellent cornering.
    MoabMonster
    Oct 2007
    It's pretty much the perfect Highline setup for technical DH
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Endomaniac
    Can any of you guys comment on the handling differences of your highlines with a 200mm dual crown fork compared to a 180mm single crown. Are you using a flush lower cup with the dual crown? Do you have 7” rear ends?
    Handling difference? Realize that 7" singe crown forks have about the same axle to crown as 8" dual crown forks, so there really isn't much of a difference.
    A flush/zero stack headset will probably have more difference than the 8" DC vs 7" SC.
    Quote Originally Posted by Jayem
    I didn't realize that. So my Totem is about the same height as a Boxer? I had a brief ride on a Morwood with a new Boxer WC, that fork left me somewhat disaponted with my Totem.
    Reputation: airwreck's Avatar
    I feel the same compared to an old Boxxer team...
