Results 1 to 5 of 5
    5 Spot Seat tube reaming ideas?
    Any other 5 Spot owners have a hard time lowering their seat post below the welds for the shock mount? Mine gets "stuck" at about or just below that point. If I try to force it, the seatpost comes back up with gouges in the anodize.
    I'm guessing there's a weld intrusion in the seat tube. Any ideas for reaming this out? I tried a wooden dowel with some sandpaper wrapped around it with no success.
    Reputation: wfoacman's Avatar
    I read a thread awhile back about this same issue. DT chimed in and said that the seat tube is butted somewhere around the area that your talking about. It's more than just a weld intrusion.
    Thanks for the info. That makes sense given the stresses in that area.
    I'll stop fretting over it and will just cut some seat post length.
    bump and grind
    Reputation: cobym2's Avatar
    Apr 2005
    Just use a 27.2 seat post with a shim, if you want to slam the post down on descents.
    Reputation: glader60's Avatar
  1. 30.9 seat tube reaming
    By albeant in forum Ventana
    Last Post: 11-20-2011, 12:28 PM
  2. Reaming out a seat tube
    By loamranger in forum Nicolai
    Last Post: 04-30-2010, 11:43 AM
  3. Reaming the seat tube?
    By mikesnowdon in forum Frame Building
    Last Post: 12-16-2009, 06:59 PM
  4. Reaming seat tube
    By rpet in forum Tooltime
    Last Post: 12-06-2005, 05:47 PM
  5. Seat tube reaming / milling -- how much is ok?
    By Speedub.Nate in forum Tooltime
    Last Post: 06-03-2005, 04:12 PM
