5 pack fork- Mtbr.com
Results 1 to 5 of 5
Thread: 5 pack fork
    Reputation: noosa2's Avatar
    5 pack fork
    Anyone know the geometry (specifically HA, SA, and BB height) of a large 5 Pack running an '04 Talas fork (125mm travel)?
    long standing member
    Reputation: PCinSC's Avatar
    Quote Originally Posted by noosa2
    The specs for the 5 Pack given here assume a Pike up front (~518mm a2c at 140mm travel). They're showing 68.5* HA, 72.5 SA and 13.5" BB. With a 125mm Talas you're shortening the a2c by almost an inch so assume a relative steepening of the HA and SA (maybe 0.5* to 1.0*) and a lowering of the BB height. If you call CC they may have that info. That's all I got, sorry it's not more specific.
    Patrick
    close to spot numbers then
    Quote Originally Posted by PCinSC
    Patrick
    If cc numbers are good and PC's guess is good then that will put my 5 Pack very close to my 5 Spot numbers for HA and SA. I am a bit concerned as CC has the BB height at 13.5 with a Pike and if I am shortening the a2c by almost an inch I wonder how low the BB will be. The Spot, at 13.25" BB is as low as I like to go.
    I don't really have the cash for a new fork but this one seems super cheap and would be perfect on my 5 pack.
    http://www.pricepoint.com/detail/15549-315_ROC456-3-Parts-59-Forks/Accessories/Rockshox-Pike-454-U-Turn-Suspension-Fork-'07-offerIN050BB1.htm?zmam=3075515&zmas=1&zmac=20&zmap =15549
    That is a good deal. And would be perfect for the 5 Pack. Just remember to figure in the cost of a new 20mm thru-axle hub/wheel if you don't already have one.
    Patrick
