• 01-28-2014
    syraleo
    need help with 2010 Trek Remedy 8 bearing
    Attachment 865860
    as you can see from the picture, the bearing is shot.
    i have yet to open the rest but i figure they'd all need to be replaced.
    where can i get bearings for it and would i need some kind of bearing press tool?
    it's a 2010 remedy 8 frame.
  • 01-30-2014
    salsamoto
    W275322 Cartridge Bearing, 6900-2RS O.D. 22mm, I.D. 10mm, W 6mm
    Trek part number is w275322. U need 6 $7.99 each.
  • 01-30-2014
    salsamoto
    Attachment 866278 think that worked
  • 01-30-2014
    salsamoto
    Parts for 2010 Remedy Aluminum Assembly
    Item Number
    Black Part Number
    Gold Part Number
    Description
    Assembly Details
    QTY
    W273724
    Cartridge Bearing, 6903LLB O.D. 30mm, I.D. 17mm W7mm w/ 3mm Ext Race
    W282091**
    Cartridge Bearing, 6901-2RS, O.D. 24mm, I.D. 12mm, W 6mm
    W275322
    6
    5
    W284029
    W294277
    Nut, M10x1.5, 7.0mm Thick
    Torque to 150 IN-LBS
    W291021
    W294276
    Axle, M10x1.5x84mm
    W290375*
    W291595
    Axle, M10x1.5x73.6mm, 17mm O.D. Shaft
    W290376*
    W291596
    Nut, M16x1.5, 7mm Thick, 20mm Flats
    Torque to 300 IN-LBS
    W286347
    W291601
    Nut, M8x1.25, Custom fitted nut
    W275702
    Washer, I.D. 8.2mm, O.D. 10.0mm, Th 0.4mm
    W296576
    Washer, I.D. 10.0mm, O.D. 18mm, Th 4.25mm
    W282876
    W291598
    Bolt, M8x1.25x54mm
    Torque to 85 IN-LBS
    W301451
    W301450
    Bolt, M10x1.0x18mm
    W284030
    W292163
    Nut, M10x1.5, 7.5mm Thick, Mates to seat stay
    W292474
    Washer, I.D. 10.0mm, O.D. 18.5mm, Th 3.0mm
    4
    16
    W305185
    W295805
    Bolt, M10x1.0x20mm
    W307717**
    W294662
    Nut, M12x1.25mm, ABP Race non drive side, 20mm Flats
    Torque to 200 IN-LBS
    W307719**
    W294663
    ABP Race Pivot Bolt, Non-Drive side for 135x5mm axle, M12x1.25 external thread
    W304517**
    W294664
    Nut, ABP Skewer Nut
    W307716**
    W294665
    Nut, M12x1.25mm, ABP Race drive side, 15mm Flats
    W307718**
    W294666
    ABP Race Pivot Bolt, Drive side for 135x5mm axle, M12x1.25 external thread, M10x1.0 der hanger thread
    not pictured
    W295905**
    Skewer Nut Nylon Insert 5mm
    *427337
    Technical Trail/ All Mountain Main Pivot Kit contains all parts marked with *
    **427345
    ABP Race Pivot Kit contains all parts marked with **
    297286
    Sag Gauge, Fork, 140/150 travel
    W286425
    Sag Gauge, Shock, for Remedy
  • 01-30-2014
    salsamoto
    If it's really hard to read send me a message with your address and I'll print it out and mail it to you.
  • 02-02-2014
    syraleo
    thanks, i found that document too.
    now the question is, where can i get a tool to push out the old bearing and install the new one.
    first time doing this.
  • 02-02-2014
    timmaayyy
    I did mine last year. I just used my vice and some sockets. I followed a video that someone made, let me see if I can dig it up.
    Also, I used the bearing sizes from the tech doc and ordered them online, I think from Tree Fort Bikes.
  • 02-02-2014
    syraleo
    i saw a video for a trek fuel ex, i assume it's the same but i dont have a vice at home...
    got my bearings from a local bearing manufacturer, about 3usd each.
  • 02-02-2014
    timmaayyy
  • 02-12-2014
    syraleo
    are we able to buy the washers online? i lost 2 of them somehow...
    W292474
    this particular washer.
