DT Swiss M1900 wheels- Mtbr.com
Results 1 to 10 of 10
    Reputation: BmoreKen's Avatar
    Sep 2004
    Anyone have any details on these wheels? Points of engagement? Inner rim width? Number of spokes? Good for clyde? Etc.?
    I can't find anything online.
    Posting here because they are stock on several Treks.
    These wheels came on my Fuel EX 9.8. The manufacturer's specs can be found here:
    https://www.dtswiss.com/Wheels/MTB-W...1900-Spline-en
    Sep 2004
    I saw that, but they don't specify which hub: 250, 350, other, non-DT? And the POE isn't clear. Is it 18?
    It does list inner rim width as 22.5mm, which answers one of my questions.
    Thanks,
    It is not the 240 hub. It is most likely the 350. I only used those wheels a few times before I bought a set of I9 trail 245s. All I can tell you is there is a huge difference in the engagement. I hope this helps.
    Jan 2011
    It's not a star ratchet hub, so not a 240/350 etc. It uses pawls, and does not have the same reliability or upgrade possibilities of the higher end DT hubs.
    Aug 2015
    I've got the E1900 wheels on my Remedy, how similar are they to the Ms?
    Jan 2011
    The E1900 is pretty much the same as the M1900 but a little wider rim with a build designed for the AM/Enduro type bike. Same pawl system, no star ratchet.
    Free your heel...
    Reputation: hopsalot's Avatar
    I've got these wheels, Rem9.8-29r and they have been performing better then expected. Very stiff, plenty wide, engagement isn't terrible, hold air tubeless like a champ, still true and round after some of the bigger drops. Kinda heavy is my only complaint but a great stock wheelset so far.
    Aug 2015
    Can the hubs/pawl system be upgraded? Or not worth the hassle..?
    Free your heel...
    No, however the cassette carrier is convertible from Shimano to a Sram XO driver if someone is leaning Sram 1-11.
  1. Mavic Crossride or DT Swiss M1900 Spline for 27.5
    By Akio in forum Wheels and Tires
    Last Post: 03-19-2015, 11:57 PM
  2. Replies: 8
    Last Post: 03-17-2015, 08:48 AM
  3. Dt Swiss m1900 hubs help
    By Dagonger in forum Wheels and Tires
    Last Post: 04-23-2013, 10:16 PM
  4. Replies: 5
    Last Post: 09-11-2011, 04:40 PM
  5. Replies: 2
    Last Post: 09-10-2011, 08:47 PM
