Can a 2016 Trek RE:aktiv shock be mounted horizontally?- Mtbr.com
Results 1 to 3 of 3
    Jul 2017
    Not sure if it will work, but looking into fitting a 2016 Fuel EX shock on an older superfly frame (with some mods) that will mount the shock horizontally for a friend. From my understanding there is no reason it shouldn't work horizontally due to the only difference being the oil damper that is under pressure, but i figured i would check since all the Trek frames seem to have them designed vertically since they went full floater.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I'm a little confused by your shock orientation references, but the Reaktiv feature is in the damper with oil and no air, so orientation doesn't matter. AFAIK, full-floater shocks were oriented vertically, with the top attached to the seat stay rocker and the lower end attached to a forward extension of the chainstays.
    Do the math.
    Jul 2017
    Thanks LR, i edited the original post so the orientation made more sense, sorry about the confusion.
    I really just needed someone to confirm the shock will work mounted horizontal, which it seems it would, so thank you!
  1. Replies: 11
    Last Post: 11-30-2015, 10:24 AM
  2. Trek RE:aktiv Shock Durability
    By Ifly in forum Shocks and Suspension
    Last Post: 12-11-2014, 11:59 PM
  3. Replies: 18
    Last Post: 04-25-2013, 10:37 AM
  4. Can I store my bike with my fork hanging horizontally?
    By Freewillie in forum Shocks and Suspension
    Last Post: 08-07-2008, 12:21 PM
  5. Replies: 3
    Last Post: 03-20-2006, 05:13 PM
Members who have read this thread: 25
