what is the main difference between transition scout 2016 vs transition scout 2015 ?- Mtbr.com
Results 1 to 5 of 5
    Sep 2013
    hello, guys !
    i`m checking an option to trade-in my #BANDIT to SCOUT
    but cant figure out what is the main difference between transition scout 2016 vs transition scout 2015 ?
    if anyone knows or can tell me some details about it...
    Best regards
    Apr 2014
    Colors and 2016 offers some Spec/Pricing options
    If there's no mountain, it's just biking.
    Quote Originally Posted by Michael Khudashvili View Post
    hello, guys !
    Best regards
    The 2016 scout, aside from a few parts that are different I believe, raised the BB 5mm and is spec'd with 170mm cranks instead of 175. The 10mm, believe it or not, really helps out with the pedal strikes which are kind of annoying with the 2015 model until you adjust your riding style and use the crank at the top of the stroke like a gas pedal and then back it off to avoid striking when appropriate.
    Reputation: mtbiker040's Avatar
    2015 to 2016 changes are colors and BB raise 5mm + 170mm cranks spec'd
    if you go 2015, get some crank boots and remember how to ratchet pedal!
    '15 Transition Smuggler
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    Just received my 2016 Scout 4, and it did come with 170 mm cranks and a slightly higher BB.
    GRAVELBIKE.COM - ride everything
  1. gals on Transition Scout ??
    By fishercat in forum Women's Lounge
    Last Post: 02-17-2016, 12:46 PM
  2. Transition Scout owners, I need advice.
    By MATPHAT in forum Transition Bikes
    Last Post: 08-03-2015, 06:35 PM
  3. Transition Scout in Bay Area?
    By bikenacho in forum California - Norcal
    Last Post: 03-19-2015, 12:08 PM
  4. 134 DL or Transition Scout ?
    By Rated R in forum Kona
    Last Post: 01-29-2015, 09:25 AM
  5. Transition Scout
    By gooutsidetoday in forum Transition Bikes
    Last Post: 01-15-2015, 08:12 AM
