Covert with 200mm shock?- Mtbr.com
Results 1 to 6 of 6
    Hi!
    I just wander if I could put 200mm shock on my Covert.
    With offset mounting hardware (-6mm) it would be 4mm too long, so shouldn't be too much issue I think.
    Did anyone try this?
    you will alter the geo for sure, it would not be a lot, but going in the wrong direction. and if the stroke is longer the rear wheel could contact the frame..all in not a good deal.
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    ok, I thought so
    I just can try out my friends CCDB, but I will leave it in this situation.
    Thanks a lot.
    May 2013
    Hi,
    just changed as you suggested. Resulting in roughly 170 mm rear travel and little strange geometry. Replacing the 160 mm fork with a 180 mm, all back to normal with a little higher BB, but not much maybe a cm, as i ride with more sag now, pretty plush.
    could call it a super enduro now.
    right on! anytime you go outside manufacturers specs its always a risk, glad it worked out bro!
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    May 2013
    Hi, thats what i like with transition, they always seem to have some additional room for going slightly off the initial build without becoming strange or wobby.
    Next step is cnc'ing a new rocker giving more travel out of a stock shock. Some like 165 or so, resulting in a pretty slack head angle. Some where round 65 degrees. Coverting the covert in a mini downhiller.
    Uli
